Question about Dryers
Flame will come on for about 1 minute then go out. then will periodicaly go on and off takes forever to dry a load
    Sergeant:
    Champion:
  • 311 Answers
Possible clogged venting. Try running without vent attached to see if it improves and let me know. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
I have a maytag gas dryer (Model DG303) that takes forever to dry clothes. The flame ignites but I don't know how long it stays on. The exhaust tube usually does not get very hot. Most loads take well...
I suspect you have intermittent gas valve coils. These are very common to fail, usually fail intermittently, are inexpensive and easy to replace. You will need to remove the front panel to access them and they are on the LH side once the front is removed. Replace both coils.
http://aplusapplianceparts.com/searchquick-submit.sc?keywords=279834
Dec 29, 2010 | Dryers
What about the drying time takes forever. I already replace the thermistor, its resistance test failed, I checked the vent lines, cleared all the vent from dryer up to the attic and finally I replaced the...
you still have a block somewhere.remove the duct that the lint filter slides into,make sure the outside vent is clear and blow out the vent line with a leaf blower,i told this to someone else and they blew a birds nest out of the line and they said the line was clear,also remove the t-stats on the blower wheel housing and check the back of them,sometimes lint and dust gets stuck on the back of them and they don't read right.if that looks fine change out the gas coils but i'd say you have a clog somewhere
Sep 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmore sreies 80 gas dryer, doesnt heat well'
replace the ignitor or the gas selinoids
Apr 20, 2010 | Kenmore 72802 Gas Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Dryer takes forever to dry clothes
firstoff, youll need to check for a clean not kinked vent, mosttproblemswith "too long to dry are genrelly tracedback to innadequate/poor venting"
Jan 26, 2009 | Whirlpool Dryers
Very long drying time
ck vent system if vent not oper it can cause flame roll out and shut off unit also ckd flame sensor on side of burner
Jun 01, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Dryers Experts
