Question about StarTech.com StarView SV211K 2-port KVM Switch
Super box how do i enter the codes using my remote 4 my super box please help
  • tony rimmer Nov 28, 2008
    i have same problem can u help me pls
  • treemacpart Dec 01, 2008
    can any body tell me what to go to n how i put the codes in using my remote pleeeeese n wats the code
Go in to menu and press the yellow button
Posted on Nov 28, 2008
I have apex dt-250a digital converter box and I lost the remote. Purchased RCA universal remote and I have not a clue what codes I need or how to enter them. Can you help?
I programmed a Radio Shack 5-in-one remote to my Apex DT-250. Select cabel/satelite, hold p until the light blinks twice, then enter the code 0749. It works! If your universal remote uses a three digit code, use 749. If it uses a five digit code, use 00749. I HAVE A PROBLEM THOUGH... I don't know how to scan for channels! It says "please do auto channel search", but how do I do that? Please, if anyone has this answer, let me know. I finally programmed the universal remote, but it's basically useless without being able to do an auto channel search.
Jan 31, 2011 | RCA Televison & Video
Need new codes for star view box super on virgin/ntl
this box updates automatically. virgin have found a way to cut the signal off. you can press menu then numbers 1570 and go onto nagravision menu and it will tell you how to enter the code.
if you can't get this menu then you havent got the right firmware in the box. hope this helps.
Dec 20, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Looking for codes for super box please
Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Aug 26, 2009 | StarTech.com StarView SV411K 4-port KVM...
Need Universal code for RCA remote with Apex DT250 Digital Conver
Use cbl/sat button. Your remote might use more or less than 4 digits. Use 749 or 00749. It'll probably work. It worked for me.
Jul 30, 2009 | Televison & Video
What is this tv's setup code? Needed for Comcast cable box opera
are you sure that your comcast remote requires xxxxx 5 digits for the TV code ?
10054 ?
most remotes use 4 digit codes and in my book, the philips codes are:
0054
1454
0690
1154
try these
and if you are sure that the comcast remote uses 5 digit codes then try these
10054
11454
10690
11154
make sure you get the Red LED code entered Confirmation Blink after entering the code digits.
its either a double blink or a Long Solid blink
if you have 4 digit codes it will blink before can enter the 5th, so you will know
Ed
Jun 16, 2009 | Philips 13PT30L 13" TV
The Box, The Box Super, NTL area, not all channels coming in.
Not 100% certain that this'll work but this is what I did & hopefully it'll work for you too - good luck :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Apr 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
The super box
  • For starview super box
  • Press MENU
  • Press 1570
  • Go to NAGRAVISION and press OK
  • Go to Key Number with the arrows on your remote, press two times to the right. Now you should have 00 again
  • Go Key Data and enter this code: B0 B8 4F 04 E6 5F 87 80 and press OK.
  • Go back to Key Number and press arrow to change to 01
  • Than go back to Key Data and enter code: A3 EB EC 07 06 49 D2 EB and press OK.
  • Last step: press EXIT 3 times. Your channels should be now restored.
  • Ps. Make sure to install all numbers and letters of the code don’t over look any of them for this will cause problems reinstalling your channels….
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Dec 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Entering new codes using remote control
hi go to afterdawn.com you will get all the help you need.hope this helps.
Dec 01, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
51 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
