Question about Hobart Kitchen Appliances - Others
Change hobart gfo53a deep fryer natural to lp gas
Need to no whether to adjust or change orfice if adjust where?
  • Anonymous Mar 28, 2014
    it was originally natuaral gas but needs to be restored - where could i find parts for the Elite efs-40
  • 390 Answers
The orifice is not adjustable but there is a small air sheild around it that is held in place with 1 screw and needs only to be adjusted if the flame is not of a blue color (starting to get a yellow or orange color in it).
Posted on Nov 29, 2008
Cecilware fms40 fryer convert to lp gas
Most NatGas devices will convert to use of LP by changing the orifice.
GRINDMASTER CECILWARE F177A ORIFICE 52 1 16 LP GAS
Oct 05, 2015 | Cecilware FMS-40 Deep Fryer
Want to convert to lp gas. has a wr safety valve with a oem #1173wr
To convert a natural gas fryer to LP, you have to change out the orfices... We can order the kit for you and have it shipped in 1-2 days...Call Ray at Restaurant Equipment Outlet, 888-542-5959, with model and serial number of your fryer... Thanks, Susan REO Cincinnati, Ohio
Sep 08, 2011 | Imperial IFS50OP Deep Fryer
How can I convert from natural gas to LP?
change your gas get from natural to lp and use an lp regulator. you may have to adjust your air flow for proper flame
Sep 16, 2010 | American Range AF-25 Deep Fryer
Bought a four basket fryer on an auction. It is a Model bb14, serial m25860 not sure if it is now Lp or NG. Pilot lights for both sides but does not light burners. Can hear the click on the thermostat....
Natural gas and LP gas run on different pressures. If it has been set up to run on LP and you hook it up to natural the burners will be very small and may not light due to LP works on a higher pressure than natural. If it is set up for natural and you use propane the flames could be way overgassed. One thing to check is what the appliance regulator spring is set for. There will be a cap on the regulator and when you remove the cap there is usually a small metal ring inside that sets the spring tension by flipping it's position. On top of the ring it will say NAT or LP. Now if you find this ring set on NAT then the appliance was probably running on Natural Gas and vice versa. If it is set up for LP and you go to Natural than the orfices can be drilled out and the appliance regulator tension cap flipped. If it is set up for Natural and you go to LP than it is best to replace the orfices with LP ones.
Sep 04, 2009 | Keating Instant Recovery 14BB (NG) Deep...
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
I have two dean sr142gps fryers and am looking for an owners manual. I want to know how to adjust the flame onthe burners.
The only way to adjust the flame is by changing the orfices on the burner tube manifold. Dean is owned by Frymaster & you can contact their technical Dept @800-551-8633
Jul 19, 2009 | Kitchen Appliances - Others
Label says propane, needs to run on natural gas.
You need to change the gas valve,burner orfices,pilot and maybe a gas regulator.I service these fryers often as im a hobart tech.Goto hobartcorp.com,type in your model and the parts list.Any ? let me know.
May 06, 2009 | Vulcan EF3 Deep Fryer
Want to change natural gas to propane
You need to change the regulator,gas valve and burner orfices and possibly the pilot.If you have a commercial fryer go to 3wire.com and you will find the part's you need.Any questions?
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Need manual for garland deep fryer model G22-18F Fryer is natural gas and want to convert to LP
Goto 3wire.com for the manual.You will need a gas valve,pilot and burner orfices to do the conversion.This site also sell's these part's.
Apr 03, 2009 | Garland AF-5025 Deep Fryer
Kitchen Appliances - Others Logo
110 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
