Question about Sony Ericsson K510i Cellular Phone
My phone when I charge it is saying it's fully charged but it can't be beacuse I have not used it for months. When it comes on, it asks for the pin number but only lets me enter the second row of digits...the top row( digits 1,2,3) will not work on the screen, I press the button but nothing comes up.
    Genius:
  • 1,011 Answers
Dear,
did u tried or open the internal cassing . i think any button is permantly pressed or causing this problem. u have to open the cover again of if first time then clean its keypad and then intially charge the full battery and then check.
try to do a master reset/default factory at the end, if issue is still persisting. But save contacts and sms first.  reset can delete them
regards,
Posted on Jan 01, 2009
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
Battery lufe is rubbish
How old is the phone/battery?
Most cells use LiPo batteries, which can be very tempermental. If they are fully discharged (used until they will not power item any longer) more than a few times, they can lose the ability to hold a charge. Also, check the phone's users manual for correct battery charge times, as many Li/Po batteries will show a full charge before they are actually fully charged, particularly for the first few charges. If your battery isn't holding a charge, the easy fix is to replace it, but if the phone/battery is less than 6-12 months old, I'd ask my cell provider to replace it as defective.
Hope this helps,
r
Sep 12, 2011 | Cell Phones
I have one sony ericision w700i mobile but not charging the mobile
sony ericsson mobiles generally comes with data cable pin type charger.. these type began to loose after a regular usage try adjusting the charger pin to get charging.. if there is no use, we have to change the charger pin located in your mobile.. ask your nearest service center of sony ericsson inorder to change the pin..
Sep 14, 2010 | Sony Ericsson W700i Cellular Phone
Does not charge fully. n when in charge when call come it stop charging
u had to purchase new battery or ur charger wire is lose use pin charger to charge ur battery
Mar 22, 2010 | Cell Phones
Does my phone have to fully charge before i can use it again?
No, try and remove the battery again. wait a few minutes.
Now replace the battery, plug the phone in, now press and hold the call button which is the on button for 10 seconds and see if it powers up.
Any more questions just ask.
Feb 07, 2010 | Motorola Mobility RAZR V3
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
Jun 01, 2009 | Apple iPhone 3G
I havnt used nokia 6300 for 3 months , how to recharge battery
Because it has fully discharged, the battery has to be replaced. Try replacing the battery.
Rate this.
Apr 29, 2009 | Nokia 6300 Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Sony Ericsson K510i Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
