Question about Lexar LDP-600 MP3 Player
Memory loss My Lexar is 2 years old.Recently i found a problem wit it.Everytime i switch it off all settings like display colour,equalizer,power save etc are resetted to default.please suggest a sol so that my settings are saved.
  • 102 Answers
There is a built-in memory that saves your settings and keep the clock working while the device is shut-down. If the device has it built-in. then it's hard to replace it. If it could be replaced then replace it and you are good to go.
Posted on May 24, 2007
Equalizer setting
memory dead or control chip bad..dealer item
Jan 01, 2014 | Cars & Trucks
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
I have a lg 52lg50 lcd tv,everytime i turn tv back on,i lose all my channel memories and re auto tune,its not the cable because if i disconnect tv while on and hook back up channels are there .only when i...
This memory loss issue sounds like a problem with the main board inside the TV. The channel memory should not erase after a power cycle.
You are probably loosing other custom programming like your Display and Audio settings. That is if you had modified something in these menus.
You may want to check to see if this is also happening by making a change in like the Display menu, and then turn the unit off and back on.
The TV has a one year warranty on parts and labor.
May 20, 2010 | LG 52LG50 52 in. LCD HDTV
Colour change and sound loss
I found that simply by switching the player off and unplugging it from the electricity supply for approx 1 hour, when switched back on every thing was ok again.
Ron
Jan 10, 2010 | Philips DVD634 DVD Player
My 19'' Samsung LCD TV is over a year old. It
There would be a battery called CMOS battery, which sould be used to save the settting when switched off, THis battery would be dried so the settings cant be saved, call Please get CR2032 Battrey and change it, it would solve your problem
ENJOY RATE THIS SOUUTION
RNJ VINOD KUMAR
Sep 10, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
REPLACED STEERING COLUM
You May need to Use The Old Ignition Lock & Key ,Due to the Chip In the Key.
Circuit Description
The PCM has a memory area where it stores certain data it needs to save when the key is turned OFF. This area is called Keep Alive Memory. This diagnostic test monitors the PCM's keep alive memory for a loss or unintended change of data. If such a condition occurs, DTC P0603 will set.
Conditions for Setting the DTC
Test Condition
Test continuously.
Failure Condition
Keep alive memory checksum does not match previous checksum.
Action Taken When the DTC Sets
  • Clear all keep alive memory locations.
  • The Malfunction Indicator Lamp (MIL) will not illuminate.
  • No message will be displayed.
Conditions for Clearing the DTC
  • A History DTC will clear after forty consecutive warm-up cycles with no failures of any non-emission related diagnostic test.
  • A Last Test Failed (current) DTC will clear when the diagnostic runs and does not fail.
  • PCM battery voltage is interrupted.
  • Using a Scan tool.
Diagnostic Aids
If the battery has been disconnected for any reason DTC P0603 will set. The PCM keeps a running check on the memory; if memory changes it resets. An intermittent loss of power or ground to the PCM will cause a reset.
Jan 25, 2009 | 1996 Oldsmobile Aurora
All stored settings are lost everytime i switch of my car.
You have not installed your radio correctly........
there is suppose to be 2 power in for the radio
1 that holds memory for the radio has to be picked from a line that has power available to it even if the car is switched off
and the other just to switch on the radio itself...normally responding to ignition
check to verify that you have connected the memory power for the radio correctly and that that line has power even though the car is switched off......
use dc tester to test that it has power available
This will work for ya
keep me posted
Please don't forget to vote
Cheers!
Nov 14, 2008 | JVC KW-AVX706 Car DVD Player
Memory card
the best thing that you can do is reformat that card.
hope this helps.
Jan 14, 2008 | Sony PlayStation 2 (PS2) Console
RCA F31317 lost blue in picture.
this symptom is characterised by the loss of one or two primary colours. this symptom can be classified into three cases: 1) loss of red colour, 2) loss of colour blue,3) loss of green color. this symptom may be caused by a trouble in the colour demodulator, in the color amplifier or in the colour subtraction amplifier circuit. in your case loss of blue colour. this is a very complicated problem that you need some special test equipment like oscilloscope and color pattern generator in order to trace the signal. tune the receiver to a color broadcast station(a colour bar generator can be used to transmit a colour signal to the set). check the Z-axis demodulator, z-axis amplifier and the B-Y output circuit for the chroma signal. observe the signal process with an oscilloscope. if the color signal is not present use a VOM to locate the defective component in any of the above circuits. check the transistors and the resistors in the collector circuit. good luck!
Feb 14, 2007 | RCA F31317 31" TV
Lexar LDP-600 MP3 Player Logo
65 people viewed this question
Top Lexar Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
