Lg lcd dvd comb modle # ku-17wdvd
Would you be able to help with unlock codes from region one to regoin four.
  • croftys4 Nov 28, 2008
    thanks for the info and prompt response.
  • Anonymous Jan 17, 2009
    the rating is locked
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Offhand, to my understanding this particular model was manufactured with specs from Zenith USA intended for North American market. Thus, it is not only locked to region1, it has no capability other than NTSC. The TV side would not know what to do with a region 4 (PAL) signal except display it in black & white and reduced vertical height. Another factor to consider, even if we were able to identify the DVD engine and therefore possibly get the unlock codes, the remote that was issued with the LG KU-17WDVD would not work since it is for a TV/DVD whereas most unlock codes work with the original remote of the DVD engine only. Sorry.
A favor, though I have addressed your query which unfortunately is to be the bearer of bad news, I would rather that you do not rate this solution. Due to my current standing, even a Helpful would be detrimental to my rating. Thanks.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 28, 2008
Lg bp620 , DVD region free codes query
Doesn't work. Press 0 four times did absolutely nothing.
Nov 16, 2012 | LG Electronics Bp620
DVD don't load
Is LG a piece of what?
First off let me try to figure out your vocabulary..
The answer is No there not a piece of *****
What happends over time here is the little band inside slips causing the try to open and shut and so on, will take sooe rk to fix. Being that it is a combo unit a repair bill would not be in the budget. But if you put in a disc and it ejects it before it starts to even try to read then you got a stuck HAT, the HAT is the piece that helps the motor spin the disk. The unit will need to be opened to see what is wroung inside.
Thanks and do be considerate and leave a postive rating and feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 29, 2010 | LG KU-17WDVD 17 in. TV/DVD Combo
I need to unlock the DVP-SR200P to play all regions.
Tell that to my DVP-SR200P ¬_¬
I just bought it, It's regoin 4 and it doesn't play other ones.... I just found out!!!!!
MONIQ
Oct 09, 2009 | Sony DVP-SR200P DVD Player
Code region
power on the dvd
let it load and show no disc
open tray and enter '0' four times
region edit and region code appears with the default code
press 0 for region free and enter
region code should be 0
press pause on remote
power off and on again
Jan 03, 2009 | Televison & Video
Lg dvdcombo region codes
I have just hacked an LG 32LG4000 combo tv/dvd. To open up the dvd to multi region, turn on the tv & press the menu/set up button. Next, navigate to the lock symbol but do not open the sub menu. Press 0 seven times. Exit out of the menu, and your 'on board' dvd player will play dvd's from any region!
Nov 28, 2008 | LG 32LG40 32 in. LCD HDTV
Unlock Code
http://www.digitalfaq.com/downloads/dvdhackarchive/lg5000.zip
Unpack the zip file and burn the folder to a disc.
I used Nero...
1. Burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order.
2. Insert the disk to your player
3. It loads..... After a few seconds it opens the tray
4. And a Region Select menu will come up.
5. Press "0" on the remote for multi-region. Then press the pause key (or maybe the enter key).
* Region 0 MUST appear in both of the definitions on screen
OR
Power on
wait "no disk" to appear
open tray
press 0 four times
"region edit" and "region code" appear with the default code
enter
"region code" should now be 0
pause
power off
Jun 30, 2008 | LG Televison & Video
Awa lmd5908cp region codes
Please be advised following procedure for set the region code to
multizone.
1. Power on the unit
2. Open DVD door
3. Press setup button on remote control.
4. Press right button on remote control 3 times.
5. Press 9653 continuously, then you will see the default region code on
the screen.
6. Select 0 to set region code to multizone.
Jun 16, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
