VCR is in locked position when play is pressed.
VCR has no sound or picture and I cannot find a location or even a phone n o. for Akai.
  • denisejayjay Nov 29, 2008
    No the information did not solve my problem, the vcr does rewind and fast forward and the counter does work. It appears the play feature is locked-maybe as a precaution to stop inappropriate videos being played?? I just need to know how to unlock it. Have had a TV technician try but with no success.
  • denisejayjay Dec 01, 2008
    Thanks arthurroger but no luck. Every time I press play it locks, the other functions work ok so I am guessing there is a lock feature which I need to try and find out how to turn off. Have tried to contact Panasonic - no success either.
    Novelist:
  • 170 Answers
I believe Panasonic has taken over the service and distribution of Akai.  A check on the Internet for Akai will lead you to a service link. I have an Akai combo TV-VCR that I was able to download a manual for. Parts.com may have other parts for your unit. I need more info on your unit. Does it run in play? Rewind and FF? Does the counter move? If the unit functions mechanically, be sure your patch cords are properly connected - yellow for composite video, white and red for audio. Be sure the input is properly selected on you monitor or TV.
Posted on Nov 28, 2008
  • Arthur Aldrich
    Arthur Aldrich Nov 29, 2008
    Try this: Put in an old tape or a blank tape with the RECORD tabs in place on the back. Don't use a good tape or one you want to save. Press stop, then play-record, then see if the mechanism functions properly. It sounds as though the record-play interlock may be funky. Or press pause or stop, and then play. I have seen this problem on other VCRs; usually pressing stop before entering any other commands clears it. Good luck!
When I try to play a cassette the cassette clicks on and turns normally. However, all it transmits to the TV is wavy lines and no picture of sound. The TV does not show the play, stop,etc. indictators when...
The TV channel should be set on Chanel 3 or Chanel 4.
Use the remote control of the TV to set it.
You can also use the AUX ports (to TV) on the VCR and connect the three wires to the AUX ports on the TV (TV input). The two audio wires are to be connected to Audio in and the Video signal to the Video input.
If you get a garbled picture you can use press the tracking button on the VCR. Usually you press the Channel Up arrow, or Channel Down arrow to adjust the picture.
Dec 22, 2013 | Goldstar Televison & Video
Sounds not working on super nintendo
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.well I guess that you will have to hook it up to a DVD player or a VCR player to have it work on a digital tv
Note: pictured above is the original Super NES. The redesigned Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the VCR.
Place the yellow end of the Stereo AV Cable into the Video "in" on the back of the VCR.
Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono VCR with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV Cable into the "multi out" connector on the back of the Control Deck.
After system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward Game Pak).
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen. You are ready to play!
Recording Game Play
Set up the Super NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 31, 2013 | Nintendo Super NES Console
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Jan 08, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Akai problem
i got akai 29" tv before 1 1/2 yrs back.3days back it was burnt with a huge sound. the set was burnt with a high smoke.since 1 wk i am waiting for your service agent.when they will come?this problem was not present in sony,LG,or other tv.akai is this much weak set.there was no lightnening only rain was present at that time.i hope you will change the set with free of cost.
K.P.Varghese,Plot.330/54,St-3E(East),Pragati Nagar,Risali,Bhilai,Durg(C>G)Pin-490006
Phone:0788 2271393,Mob:9424124176.
Dec 29, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
Non-operating VCR
sounds like a parental lock...but not familiar if this model has that option
Jan 16, 2007 | Akai VS-J416EA VHS VCR
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
