Question about Canon PIXMA MX310 All-In-One Printer
Is the Pixma MX310 compatible with Apple's Airport Extreme?
I have added Airport Extreme to my main home computer and then the Pixma printer. It is recognized as the printer on the Airport but when I try to print a document, the message is printer is not connected. Before I repeat the same procedure on the home laptop, have I missed a step?
    Scholar:
  • 83 Answers
Try to check your cable connection maybe its properly inserted in your port. If it continues to appear try reinstalling your printer. When installing follow the steps in the installation. Disconnect the usb cable to the PC prior to installation. You will be ask to attached it to the PC during installation before completing the installation. Check also your network settings maybe some plug ins are disconnected. After installation it needs also to restart the pc so that new changes of the settings will be detected.
Please rate this solution so that I will have more bases to suggest if you will elaborate on the result.
thank you.
Posted on Nov 28, 2008
Airport Extreme, Mac Cube and proposed Blue Ray /WIFI
Yes, you just need to connect the Airport to the modem. That way, the Airport will fetch the internet connection and distribute it to all your WiFi enabled device. You don't need any other hardware. You just need to configure the airport using your Mac computer.
Here's a quick setup guide from Apple.com:
Setup Airport Extreme
Jul 23, 2010 | Apple Computers & Internet
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Can not get my MX310 to work on the wireless network using apple airport extreme and mac
The MX310 is not a wireless printer. You must use a USB cable from the computer to the printer to print.
Mar 06, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 - I'm trying to connect this printer to my network. Currently, I have the printer connected to an Airport Express but when I try to print from my iMac, I get a message that the printer is...
Adkinsdave, keep in mind that often having someone remotely connect to your computer with you and perform this task is easier than trying to walk you through steps and potentially missing a step. With that being said, the Airport Express was meant to make setting up a WiFi network in your own home a breeze.
We need to first determine if your Canon PIXMA MX310 has a Mac driver. According to the Downloads page at Canon.com, there are several Mac drivers available for OS X, 10.5 and 10.6: usa.canon.com - simply choose your OS on the pulldown from that website. Once your computer has the driver it needs to communicate with the printer, you can use your Airport Express to connect to the printer.
Obviously, make sure the printer is turned on and once you go through the Airport Express connect guide you should be printing in no time.
Let us know if there are still issues.
Nov 13, 2009 | Canon PIXMA MX310 All-In-One Printer
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
MX310 - Wireless network printer used on an Apple Airport Extreme
Here's what worked for me: I had everything set with my wireless network which included an Airport Extreme base station and two Airport Express units to extend range. I still couldn't plug and play with my printer. 1. You have to plug your printer into the Airport Express, turn it on, then select a document to print from your computer. 2. Select print from the pulldown menu (or select 'command P' on the keyboard). 3. When the print dialog window appears, go to the "Printer:" selection bar near the top of the window and select "print & fax preferences..." 4. This opens a new window, "print & fax." Near the bottom left of this window just below an icon list of your printers are a "+" button and a "-" button right next to each other. 5. Click "+". Yet another window opens which will reveal a list with your printer on it. 6. If you don't see your printer, click the "default" icon in the top left hand corner of the new window. 7. Select your printer, then click "add" on the bottom right hand corner of the window. The window will close automatically and return you to the "print & fax" window. 8. You should now see your printer in the list. You may say, "My printer was already in the list," but that's not good enough. The process you just went through enabled the computer to detect it on your network. You may want to use the "-" button to remove any previously listed printers from the list in the "print & fax" window. 9. Now you should be able to close the "print & fax" window and get some wireless printing done.
Mar 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Scan function won't work with Mac OS10.5.5 & Airport
I plugged the printer cable directly to my laptop instead of trying to scan using the airport wireless router. Plugging it in did the trick.
Thank you,
Jtoussa
Nov 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Cant connect to internet with Airport Extreme 802.11n
An airport extreme is just a dunb Wireless Access Point. It could be that it has been mated to the Linksys router and is looking at a different set if IP addresses that are not coming from the etherent connection out of the wall.
If you know how to obtain network addresses on your computer, find out what you get from the wall jack and from the airport through the Linksys. You can try to reset and reconfigure the Airport, but if you are not familiar with the hardware, get someone who is to help you. The manual offers several tips and procedures to do this http://manuals.info.apple.com/en/AirPortExtremeBaseStationSetupGuide.pdf
Carl
Oct 09, 2008 | Apple AirPort Base Station
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
161 people viewed this question
old marine
old marine
