Question about Garden
Chain saw starts with starting fluid only but will not run.
Echo cs-345 chain saw . 2-3 years old used very little. Fresh gas and oil mixture. Is there a way to check the carb? other things I could check?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Posted on Nov 29, 2008
  • Paul Sep 21, 2013
    already done all that now won't fire with starting fluid
Oil ratio for my Swedish made jonsered chain saw model 625=2
Using only a high quality 2 cycle oil mix 2.6 ounces of oil to a gallon of fresh gas.
Sep 30, 2014 | Oregon Jonsered 13" Chain Saw Repl. Chain...
Chainsaw troubleshooting
Fuel can chemically decompose in as little as two weeks, especially if it's an ethanol blend. Try to avoid ethanol-blended fuels.
Dec 16, 2013 | Garden
I have a 435 husquvarna chain saw it is hard to start plus it idles high and it smokes and the chain keeps spinning when i let off the trigger
if it is hard to start and smokes sounds like the fuel is to old and the oil to gas mixture is wrong start off with some fresh fuel gas is only good for 30days in small engines
Aug 22, 2012 | Husqvarna 450 e-series 18" Chain Saw
How to start
i would drain the gas unless you know it good 50-1 mixture. Try starting fluid make sure its running to lean. once it starts up the idle
Dec 28, 2011 | Garden
Need to know gas oil mix for echo cs 345
50-1 as with all 2 cycle chain saws
Aug 21, 2010 | Garden
What is the oil/gas mixture for a 20" chain saw?
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 28, 2010 | Poulan Pro Chain Saw 46cc 20"
Port in front for oil and the back is for gas and mixture
Hello Andre;
I think you are saying you put oil/fuel mix in the oil tank and bar oil in the fuel tank; discovered your mistake drained both tanks and refilled with the correct fluids. Now the saw runs but smokes excessively. I think it will do no lasting harm. After you have run a few tanks of the correct mix (50:1) through the saw. Remove and clean the muffler and spark arrestor, reinstall them. Inspect your plug if any evidence of fouling replace it. I think you will be cutting with this saw for years.
Yes the additional smoke is caused by a very oil rich mixture and should abate with each fresh tank of fuel. If the chain is not moving ensure the chain brake is not engaged.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 23, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have inherited my dad's Echo chainsaw - CS-3900, but not the manual. My question is simple - how do I know if I should use a 50:1 or 32:1 oil to gas mixture?
Oil to gas mixture is more a function of the oil than the saw. If you use high quality oil like Echo brand, (or Stihl or Husqvarna) you'll be fine at 50:1. If the saw is older than 15 or so years you'd be a little safer running 32:1. It'll just smoke a little more at 32:1. I wouldn't worry about it too much.
Apr 19, 2009 | Garden
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
821 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
