Question about Canon Elura 60 Mini DV Digital Camcorder
Elura 60 I have been having an intermitent problem with my camera rejecting tapes. After using a tape for a while the camera screen will read "remove the cassette" and automatically eject the tape. Regardless of what I do, it will not accept a tape. Then later (much later) it will accept the tape again and work fine for a while. I cleaned the heads with a dry cleaning tape and thougth the problem was solved, but it has recurred.
  • cvalsan May 08, 2008
    I had the exact same problems described here:
    1. The camera zooms in all by itself
    2. It won't accept the tape, giving me the message "remove tape." I only use NEW TAPES, and in the last couple of years I only recorded about six of them, so I have used it rather lightly...I won't buy a Canon again, but meanwhile, how do I fix this so I can retrieve my home videos?
    Calin
    Problem Solver:
  • 6 Answers
I had this problem this weekend with an Elura 65, where the camera would not accept a tape. If you inserted a tape, it would beep a few times, the LCD screen would flash "REMOVE CASSETTE TAPE" and then it would spit the tape out. I had the camcorder stored in a ziplock bag in a cool / dry cabinet in our spare bedroom. None of the previous solutions worked for me (clean the heads, take out the batteries, remove power for 20 minutes, remove the memory card, etc).
What worked for me:
I left the main battery in, installed the small memory battery, installed the SD memory card and plugged in the power cord. I left the camera out (close to my computer), which is upstairs in my house- in a 70-75 degree Farenheight environment - for 24hrs. After 24hrs of sitting out and being plugged in to power, I suspect everything came to an ambient temperature and the camera worked fine. (you might try up to 48hrs of being warm)
I suspect that most people's cameras are having this trouble when the internal parts of the camera are not all warmed up so the camera will reject a tape because something is functioning properly when cold.
If you look at the timing of these postings, you will see that most people are posting issues in the cold winter months. I won't buy another Canon Camcorder, but am appeased at it coming back to life long enough for me to download my information to my computer.
If you call the service support for Canon (which I did), they will ask you for your serial number, model, date of purchase, name, email address & mailing address. They will ask you to mial your camera along with the printed information above and detail your problem. It will take 7-10 business days for someone to contact you via email or phone.
Good luck with your camcorders!
cjammin - Cedar Park, Tx
Posted on Jan 08, 2008
I can't get the camera to accept the cassette, old or new, clean or dirty. They ought to give these cameras away in Cracker Jack boxes
Posted on Nov 12, 2007
    Scholar:
  • 35 Answers
Hi, When you say you're "using a tape for a while", can you define "while"? The thing about these little cameras is that they don't like to re-use DV tapes. If you are recording over tapes that have previously been recorded on, then your camera could be fussy about that. You can clean the heads, but if the tape is dirty, then it will transfer that dirt back to the heads and youp;ll end up in the same position. The problem is, that the heads will wear out if you clean them to often. In the long run, it's best to use new, clean tapes. And when you are using the tape cleaner, make sure you are following the directions very carefully. NewMediaMan
Posted on Jul 09, 2007
My tapes keep getting rejected
it could be a tight tape witch case it will just spit it back at you
the other thing it could be is the battrey is getting down
Oct 26, 2009 | Canon Elura 50 Mini DV Digital Camcorder
Thick stripes on the recording on mini dv tapes
Stripes are either caused by -
Bad tape - try a new tape
Dirty tape head - can it be cleaned? Cotton wool bud and some metho?
Electronic fault.
Try a different tape first.
If that doesn't help, clean the head. Is it under warranty?
Apr 25, 2009 | Canon Elura 60 Mini DV Digital Camcorder
Is there a better (brand) tape to use with a Elura 90? I read somewhere that certain tapes had more problems than others. Thanks, Joe
One thing that can change the tape quality is making sure you are using th 60 minute recording mode vs the 90 minute EP recording mode. If you record alot, you should clean the tape heads every 6 months as well. I haven't really found any bad tapes out there (I'm sure there are some). Usually Sony and JVC are good choices to use.
Dec 23, 2008 | Canon Elura 90 Mini DV Digital Camcorder
Canon elura 90: won't load tapes
Make sure the power is on this unit and you are pluged into a good source of power. The disk tray needs power to lower. A lot of tapes get loose in there case and need to be fast forwarded and then rewound completely in order to help spool them properly in their case. And what you are experiencing sounds a lot like this. It is also possible that you need to buy a head cleaning unit for your elura and run it in the camera for 10 secs and then try again. (Did you try this with a New tape? or just used ones?) We bought a small tape rewinding unit for around 39 dollars that helps us to rewind the mini DV tapes without adding wear and tear on our camera and it seems to help with the issue of loose tapes in the camera getting rejected as they won't wrap around the tape head as nice.
Dec 14, 2008 | Canon Elura 90 Mini DV Digital Camcorder
Tape deck won't open
Hello.
1. Completely remove battery and then restore it and try.
2. If you here sound of engine when camera wants to open door but can`t shake door by hand.
If problem persist you need to open it inside and clean it.
Sep 07, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Get eject tape message
What worked for me:
I suspect that most people's cameras are having this trouble when the internal parts of the camera are not all warmed up so the camera will reject a tape because something is NOT functioning properly when cold.
Nov 29, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Canona Elura 60 problem...
What a hunk of junk. Not a month after the warranty period expired, my Elura 60 would zoom out without warning and refused to stay zoomed in. I paid Canon to fix that problem.
Now, I'm on vacation (in the Carribean for more than 24 hours) and the unit wouldn't accept a tape. Every time I tried to load a tape, it would beep five times and then kick the tape out. So I tried taking all of the batteries and media out. That didn't work.
Next, I tried the drop method. I figured the unit is broken and I'm not going to pay again to get it fixed, so dropping it couldn't break it anymore than it already is. I let the unit fall onto the throw rug in the bathroom. In then tried to install a tape. Waddyaknow! It worked.
I can only reiterate again two things: dropping the camera from about 6" onto a carpeted surface over a tile floor seemed to clear up my "remove the cassette" problem, and the Elura 60 is a temperamental hunk of junk (although the recordings and playback are pretty good, when you can actually get a tape into the unit).
Nov 12, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
201 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
