Question about Dryers
IS70C Indesit dryer will no turn on, checked fuse....nothing....
    Novelist:
  • 161 Answers
First you should make sure power is getting to the dryer, this should be done with a meter on the A/C setting where the dryer plugs in. Next, check the door switch, this will require a meter on the OHM setting. I would buy a meter at an appliance parts store, they will show you how to use it. It's not that difficult to use and everyone should have one.
Posted on Nov 30, 2008
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
Bud
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
For parts go to the following webpage.
http://www.ransomspares.co.uk/parts/brands/indesit/tumble-dryers/is70c/
Oct 16, 2012 | Indesit IS70C Electric Dryer
When you turn the dial and hit the on switch it trips the electric
sounds like heater element gone check it first its on the back
Jul 15, 2012 | Indesit IS70C Electric Dryer
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
Indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 10, 2012 | Indesit IS70C Electric Dryer
The light on the water drawer of my IS70C dryer is staying on and the dryer isnt drying.
Thank you for the direct question but unfortunately we don't work on Indesit units and have no documentation on them, so I am unable to help you.
Sep 03, 2011 | Indesit IS70C Electric Dryer
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
Hi I have an Indesit is70c dryer it seems to work fine for 10-15 mins but then trips the fues box in the house as it cuts out. I've had a look for at the fuse and have cleaned out all filters / condensers....
Do not overload the dryer as the motor can struggle and try to draw to much power.which could cause the trip to go to out, only load drum half full.....this applies to washing machines as well"NEVER OVERLOAD THEM" with washing machines it can affect the quality of your wash as well as putting extra strain on the motor.
Nov 08, 2017 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Dec 25, 2007 | Dryers
Dryers Logo
150 people viewed this question
Top Dryers Experts
