Question about Toshiba D-R2 DVD Recorder
Toshiba RD 85-DT dr-2 error code
When ever I try and play a dvd, when it gets to the scene selection, any button I push on the remote brings up a DR-2 error message on the display and nothing happens.
  • Anonymous Mar 26, 2014
    remote control doesnt work
  • 328 Answers
Hold the easy nav button and the number 2 down for a few seconds then try using the remote.Hope this works for you too.
Posted on Nov 28, 2008
If you need to be on DR1 then press mode & 1 on the remote - dr2 is mode & 2 and DR3 is Mode & 3 - taken from toshiba user manual & worked for me
Posted on Oct 14, 2009
  • oakeyone Dec 11, 2010
    Tried this it didn't work!
I accidentally put it on DR-3 mode the remote will not work
This is also my problem, but I solved it 4 month ago but it did it again and I forgot. The answer was on page 54 in manual but there is no pg 54 on line?. Anyway as I remember the jest of it was that the remote don't care what drive it's on as long as the remote is on the same drive as the recorder. So when your recorder is saying DR-3 it's saying that what the remote is on DR-3 and you need to change the remote to DR-2...which it will work...how...I forgot it was so simple it was to buttons..hold one and toggle back and forth but I can't remember..sorry
Aug 06, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I'm from iran. sorry for my English. I have a Toshiba DVD video recorder D-R4SC model. my remote control is not working. when I want use romote control it shows me DR-2 (or somthing like this) Error on tv....
Greetings,
Check pages 44 and 45 of the installation guide (not the owner's manual.) It will tell you how to change the recorder & the remote from DR 1 to DR 2 or DR 3. To change the remote you hold the * button plus 1,2 or 3 to change the remote.
Feb 13, 2011 | Toshiba Televison & Video
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
My dvr had a timing issue and said to check the IB? or BI? so I went to the setup and seen the IB menue,.. it was on DR-1 and I clicked on DR-2 and now I can't do anything using the reomote. It only works...
Go to the menu button on your dvr look closely it wil tell you what button to use. Once there go back to setup and undo what you did. After this go into the menu where it says restore to factory settings and restore it to the factory settings. This will resolve your problem.
Aug 18, 2010 | Toshiba RD-XS52 DVD Recorder
Dr 2 message
I just sorted this on my own dvd player. push HDD and DVD buttons on the front of the player together for 3+ secs. Menu will display DR-OFF. Do the same again menu will disolay DR-2. On the remote push mode and "2" together and ths will put the remote into DR-2 mode. All should now be well.
Aug 30, 2009 | Toshiba D-R2 DVD Recorder
My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Mar 27, 2009 | Televison & Video
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ? I have the...
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
Jan 11, 2009 | Toshiba RD-XS32 DVD Recorder
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Toshiba RD-XS34
Hold down the easy-navi button and number 1 on the remote.
Sep 13, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba D-R2 DVD Recorder Logo
1,291 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
