Question about Epson Stylus 830U InkJet Photo Printer
Deep Cleaning an Epsom Stylus DX5050
Black ink will not print after repeated cleaning
  • yewbank Nov 28, 2008
    And replacing all inks
  • 83 Answers
Check the black ink level may be its already used up. It needs to be replaced. Ink is consumed during cleaning. Try to replace with a new one. all in one printers does nit print if 1 ink is lacking.
Posted on Nov 28, 2008
Replaced black ink but will not print in black epsom CX5500
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 29, 2013 | Epson Stylus CX5000 InkJet Photo Printer
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The printing is all patching and the lines are either not printed at all, some are clear and some are just spots of lines. I think the nossles may need cleaning but not sure how to. Any other thoughts?
click start
printers and faxes
right click on your printer then click properties
click maintenance
then deep ink cleaning
repeat deep ink cleaning a few times
of it fails
remove ink cartridges and blot them on a piece of cotton soaked in rubbing alcohol until it runs clean.
Apr 06, 2010 | Epson Stylus CX6600 All-In-One InkJet...
I've changed the ink cartridge in my epsom printer but it wont print, what can i do
If you haven't printed a lot lately, your print head might clogged. Here's what you can do: go to "print", then "properties", then "maintenance", and find the option "head cleaning". You will hear strange sounds coming from inside your printer, nothing to worry about, the printer is just trying to push the ink through the print head. In the end, the printer will print 4 colors: black, yellow, magenta and cyan. If the colors seem ok to you, you have fixed your problem. If not, repeat the process several times (just bear in mind that cleaning the head uses a lot of ink).
Hope that helps, and if it doesn't, please let me know, would love to help find a solution to your problem!
Mar 05, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
My Canon S750 Bubble Jet Printer does not print with black ink. It seems to print all other colors though.
Replace and install the black ink cartridge with this Black Ink Tank BCI-3eBK Ifyou have done this and is still missing the black ink on print, clean the print heads. 1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'. 3. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
That should most likely work. If deep cleaning did not help, you may need to replace the print head.
Nov 25, 2008 | Office Equipment & Supplies
Epsom R220 printing wrong colours
Print a nozzle check pattern then clean the heads until nozzle check pattern returns to normal. If you are using cheap **** compatible inks, throw them out and get some genuine stuff to run in the cleaning routine. Cheap **** compatible ink makes the situation worse when cleaning.
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Black ink not printing
You have to run a head cleaning cycle:
Follow these steps to clean the print head:
  1. Make sure the Stylus CX is on and the cp_light_183_er.gif ink light is off.
  2. Hold down the cp_button_48_er.gif ink button for 3 seconds until the cp_light_1.gif On light starts flashing. The Stylus CX runs a head cleaning cycle and the cp_light_1.gif On light flashes.
    alert_caution.gif Caution: Never turn off the Stylus CX while head cleaning is in progress. You may damage it.
  3. When the cp_light_1.gif On light stops flashing, turn off the Stylus CX.
  4. Load letter-size paper in the sheet feeder.
  5. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds. The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like:
    Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
  6. Examine the nozzle check. If it does not look like the nozzle check pattern with no gaps as shown above, repeat steps 2 through 6.
alert_note.gif Note: If you don't see any improvement after cleaning the print head three times, turn off the Stylus CX and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
If you do not use your Stylus CX often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Oct 24, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epsom Printer DX5050 Language selection
I need to change my Epsom DX8400 printing instructions to English please instead of German or Dutch. Please help
Apr 11, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus 830U InkJet Photo Printer Logo
219 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
