Question about Dryers
There is heat but clothes not drying
Hotpoint CTD00 dryer. When I put clothes in, there is heat but the clothes do not dry, even after 2 hours. Someone said that there is a small hole beside the intermediate tank at the rear. I have taken the cover off the tank but cannot find a hole that is blocked. or where water would come in.
  • 3,463 Answers
Hi/
Re you dryer problem.
Make sure the filter is clean.
Make sure the water container is fully emptied.
Make sure the condenser is clean.
Make sure the empty water light is not on.
Make sure the temp setting is correct for what you are drying.
Make sure the air intake grill or rear vents are not obstructed.
Make sure the clothes are not to wet.
Make sure the dryer is not overloaded.
If you check all these points and it still takes a long time to dry, then you are going to have investigate further.
Please leave feedback.
Thanks.
Posted on Nov 29, 2008
Got this sorted by a friend who used to be a washer reapir man.
At the back of the machine in the bottom right corner, open the grey bax and lift eh inside out to reveal the secondary tank. Make sure this is grime free. Now in the bottom left of this tank, at the back you will see a small flat slot. You will need something like a cable tie or what I used, which was the strapping that goes round cardboard boxes. Make sure this is complteley free of any blockage (fluff etc). Once you are happy with this, replace the housing and clip the box back on.
Now round the fron of the machine, remove the condensor unit and reach, with your arm into the hole that it came out of. Try and make sure that there is no dirt at the back. Mind this is a bit of a squeeze as there is a long plastic pin that sticks up in the middle at the back.
After that, remove the screws from the condensor unit and remove the front plate. I tried this myself and couldnt do it, but my friend managed with a bit of brute force. This is where you may find your problem. Mine was completel clogged up with nearly 3 years of fluff. I had cleaned (or so I thought) the condensor many times but I obviously hadnt done it right. You will need to carefully get a knife and hard flat object and remove any blockage from this while running it under a tap or shower. Once this is done. Replace the front and put screws back in. Replace condensor into its housing and you should now have a working dryer. Mine works like new now.
Apparently, if this does not recify the problem, it will most likely be a new pump thats needed.
I hope this helps someone.
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Our Hotpoint ctd00 keeps tripping the fusebox, we
Disconnect the heater thermostats by poulling a wire off each stat, and then try it, if it still trips, then could be faulty motor.
The stats are located at the rear of the dryer, behind removeable cover.
Mar 25, 2010 | Hotpoint Dryers
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Plz rate my solution.
Thanks.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
HotPoint Elec dryer heats up but doesn't dry
yes you have a vent restriction something is blocking your airflow it needs to be an open 4 inches all the way and clear describe your vent to me are you using plastic behind the dryer is it short or all mashed up don't move the dryer get a flashlight and look over the back like its sitting and describe your vent to me from the dryer to the out side if its plastic and looks like a python then you may have found your promblem
Mar 31, 2008 | Hotpoint TDC32 Electric Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Dryers Logo
167 people viewed this question
Top Dryers Experts
Marvin
Marvin
