Question about Panasonic Lumix DMC-LZ2 Digital Camera
High noise problem in the picture.
Everytime i take picture with this damned camera it looks decent when it's vied on best fit in the preview software but when i zoom in or pick the actual size it's all blurry with tremendous aboutnof noise it's grainy all over. i se the automatic settings and it's still doing it can anyone help me please.
Panasonic will charge $161 flat rate - buy new camera if out of warranty.
Posted on Sep 07, 2007
SOURCE:
Photos taken outdoors are very bright
As far as I know, Digimax 240 doesn't allow for normal ways to adjust camera settings for different environments (shutter speed, ISO settings, etc) but the menu does allow for Exposure Compensation to be adjusted (plus or minus 2 stops). Try adjusting that to find what works best for you.
Only other options are using a decent photo software to adjust on a computer afterwards, or look in to getting a camera that allows you to alter these factors for when you take a picture
Nov 01, 2009 | Samsung Digimax 240 Digital Camera
Display is black
Enable the forced Flash option and try
Jul 28, 2009 | Canon PowerShot A460 Digital Camera
My camera screen goes white everytime i turn on the camera
I Havee The Same Problem And Ive Been Reading Around And The Most Decent Answer I Found About What Was Wrong Was That Something Had Just Come Loose Inside So That Might Help Because Something Wiring Upo To The Screen Might Be Loose Its Worth A Shot.
Jul 26, 2009 | Fujifilm WL-FX9B 0.79x Wide Conversion...
No image display on camera mode
There are different settings. You can view the past photos because you are using the viewer for that, but you have a setting off in the menu. You need to turn on view photo or preview photo after picture taken. I am not sure what it is in the Canon line, but look in your manual for the setting.
Jul 13, 2009 | Canon PowerShot A460 Digital Camera
Blurry pictures
try turning of the stabilizer if you have one it will be in the settings menu
Jan 08, 2009 | Canon PowerShot SD1000 Digital Camera
Poor quality
My response to these always makes me sad. There is no way of getting good picture. These camera binoculars are neither good cameras or binoculars. They do neither well. The camera is just attached to the binoculars. What you see through the binoculars is not what the camera sees. The binoculars magnification is not the same as the lens in the camera. It is like holding a camera on top of a pair of binoculars. The camera will take a picture in the area approximate to where you are looking. Digital cameras have a sensor. The more megapixels the larger the sensor should be. Camera makers are now making compact cameras with huge megapixel capacity without increasing the sensor size. The result is worse looking pictures. Not much is different with the cameras attached to binoculars only the sensors are much worse quality than those on a stand alone digital camera.
Maybe not the solution you wanted buts its the truth. If you do want to take bird photos your best bet is a pair of binoculars on a tripod with a digital camera adaptor and camera attached. The camera adaptors that are made in China are not expensive and are copies of some of the high priced units out there. all the adaptor is is a bracket which attaches to a tripod which holds the camera to one of the binocular lenses. That way you see what the camera sees through the binoculars.
Dec 30, 2008 | Vivitar MAGNACAM Binocular
Won't connect to computer
Try setting your camera to preview option and plug it in then look under my computer for a extra drive letter.
Apr 02, 2008 | Olympus FE-230 Digital Camera
Grainy picture
hi, if the tv is not high def then the picture will not be at its best especially if it is getting converted to a analogue signal. hdmi will be much better.
Dec 11, 2007 | Panasonic HDC-SD5 Flash Media Camcorder
Panasonic Lumix DMC-LZ2 Digital Camera Logo
106 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
