Question about Dell Inspiron 1501 Notebook
Ac adapter not recognizd.
I am getting an error message that the ac adapter is not recognized and is plugged in but not charging.
  • 1 more comment
  • steve1118 Nov 30, 2008
    The adapter is the one that came with it and has been in use since last year. When plugged in the green light comes on on the charger. Whe I click on the status display for the battery it says plugged in (not charging). The laptop will not lose power while it is plugged in but will not charge further. It is stuck at 8% power. Maybe time for a new one?
  • Mark Robinson May 11, 2010
    when you plug in the wrong type of adapter into a dell laptop you get this message....check with the manual that this is the correct ac adapter for your model
  • jason May 11, 2010
    have you checked to make sure that power is comming out of the adapter? can you check for power out of it?
    Genius:
  • 1,061 Answers
You do not need a new laptop but i believe you need a new battery.RICHARDM69
Posted on Dec 05, 2008
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
My Dell D 600 will not charge the battery and a message appears at start up that says Ac adapter not recognized What do I need to do to get my computer to charge the battery
If the AC adapter is not recognized by the system, the battery charger circuit is disabled. Things you can check:
  1. In the barrel of the connection to the computer, the small wire in the center is the sensing wire. If bent or broken, then the adapter will need to be replaced.
  2. If the pin is not bent or broken, try a different AC adapter (Any D-Series Dell adapter will work) IF that adapter works, replace the AC adapter.
  3. If a known good/new adapter doesn't resolve, then a motherboard needs replacement.
Jan 10, 2010 | Dell Latitude D600 Notebook
Charger isnt recognized
Dell portables use a sensing wire in the barrel of the adapter plug to determine the wattage of the ac adapter. If that fine wire in the center of the plug is bent or broken, the system cannot ID the adapter and the battery charger is disabled.
SO, first try a known good AC adapter for a D-Series Dell (You might be able to check with Geek Squad at a local Best Buy if you don'e have access to another ac adapter) If a known good ac adapter works, then replace the ac adapter.
If a known good AC adapter does the same thing then the fault is in the charging circuit of the motherboard and the motherboard will need to be replaced.
Oct 03, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1521 laptop won't recognize a new 90 watt power
There are different types of Dell power adapters, some of them put out different amounts of power. While it is possible that the battery is faulty, it is more likely, given your error message that the adaptor is wrong. If you got it from Dell, you can call them and they will exchange it.
Cheers
Dave
Jun 21, 2009 | Dell Inspiron 1521 Notebook
Dell Inspiron 1526 cannot communicate with battery
The diagnostic Error is a False positive you can ignore the diag error as the LCD is functional. If the battery is not recognized in the BIOS or you get an warning the AC adapter is not recognized, then you may have either a damaged AC adapter sensing pin (Fine wire in middle of ac adapter connection to Laptop) or a problem with the charging unit on the motherboard.
If the sensing pin is damaged or the ac adpater is not sending the right signal to the system, the battery charger will not work. SO if you have another Dell D series AC adapter, you can try it 1st. If the battery is 18 mos to 2 years old, you might see if it is IDs in BIOS and if it indicates battery state. Also the battery should have a test button and 5 LEDs on it. If the 1st 3rd and 5th LED flash the battery is bad. ANy any come on solid, then it is a % of charge, each LED = 20%
If you end up replacing hardware, then it will most likely be in this order:
AC Adapter, Battery, Motherboard
Jun 04, 2009 | Dell Inspiron 6400 Notebook
AC adapter not recognized
If you don't get any errors when you startup on battery then all you have to do is call Dell. Get work order number and send them the laptop and adapter. They are very fast. I sent a laptop to them last month and I had it back in 3 days! I was surprised.
Dec 04, 2008 | Computers & Internet
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
Check the inside of the connector, since it is new, you can call Dell 800-624-9896 for a replacement adapter.
Sep 13, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 1501 AC Adapter error message
The Dell 1501 ac adapter (possibly other Dell’s as well) has been known to be problematic because of its lack of a plug to jack secure fit. You will notice that the plug can all too easily be pulled from the jack, as opposed to other systems where the plug fits more securely onto the jack. The plug and jack combination is poorly designed so that over time, the plug will come unseated depending on how much movement the machine is subjected to. This will result in power error messages or outright power-up failure. So before assuming you have a faulty adapter, make sure that it is not just a loose plug that is causing the problem. If you look inside the jack, you will notice that there is a 3mm region of non-conductive material nearest the surface of the jack. Use a strip of standard electrical tape 3mm wide and long enough and wrap it around the base of the plug (you may need more than one layer of tape to get a good fit). I have used this method to secure my plug and it has served me well. If the tape comes undone over time, just simply replace it. A more “elegant” method would be to use an “O” ring of the appropriate size (about 6mm) around the base of the plug in lieu of the tape.
Jul 26, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
322 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
