My climate control has stopped working. All displays appear and respond as normal however there is just no air flow. The fault is intermittant as everything came back on one day and was fully functional including the a/c. It all worked fine for about 2 weeks and now it has stopped again.
I have a 318i and my climate control is faulty one sec it will be on then it shuts off then it may or may not come back on. and i noticed around the time that started happening my right blinker would start flicking erratically. just hoping for a little info.
The climate control unit has failed,which is that unit under radio if u pull it out and disconnect wiring at the back the blower fan will come on and stay on that unit is the control unit and if faulty,
Got contoller for locking doors setting alarm wet now car wont start any suggestions
Thank you very much for your help, however I found out the problem. I also posted an email to the E36 climate repair shop on Ebay, who if anyone needs it will fix your E36 for a flat rate of £10 plus postage. When I told them the problem they said it wasn't the climate control unit at fault but actually the final stage resistor located in the passenger foot well. I needed to get a new one of these and the problem was sorted. I would highly recommend them if anyone needs help.
i have a r reg 318 i and heaters stopped working is this the climate control panel please hlp cheers craig
