Question about Electrolux EOD5310 Electric Double Oven
Electrolux EOD982 double oven
The main oven gets to 160 degrees for 10/15 mins and then switches it's self off. If I leave it for 5 mins or so I can then try again and it usual works for another 10/15 mins. Can you help?
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
  • 93 Answers
SOURCE: Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Posted on May 15, 2008
  • 3463 Answers
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Posted on Jan 11, 2009
  • 212 Answers
SOURCE: Main oven doesnt heat up. But temp light is on.
replace heating element
Posted on Jun 22, 2009
  • 8 Answers
SOURCE: Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Posted on Sep 02, 2009
Electrolux double oven model eod67043. Main oven element stays on after switching the oven off.
I recommend you contact your local serv-
ice force centre.
Here is the link to a troubleshooting part of the manual for this oven. I hope it will help.
Jun 19, 2017 | Electrolux Ovens
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
My new oven electrolux EUEE63CS WILL NOT TURN OFF. display lights turn off but oven still going
My oven seems to turn off but the fan keeps working! Takes about 1hr for the fan to turn off after l have turned oven off. Is this normal? Im quite concerned. Will be calling help line monday morning......
Jul 28, 2011 | Electrolux 30" Built-In Double Electric...
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
How do i turn on the self clean? i punched clean and it told me to take the racks out. i removed the racks, but it keeps telling me to remove them and will not do anything else?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 14, 2010 | Electrolux Ovens
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Electrolux EOD5310 Electric Double Oven Logo
532 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
