Question about HP Office Equipment & Supplies
I have a c4830 and i am unable to get it to scan to my laptop i am getting an error message which reads ( the scan cannot be performed because another program or computer is using the networked HP imaging device. try again later 8,[ (0,18,0)]
    Novelist:
  • 180 Answers
Your firewall is blocking the printer from doing it scanning. Try to turn off your firewall or try to add an exceptions in your firewall for the printer software
Posted on Nov 28, 2008
I keep getting error U043 even tho I know that the ink cartridge is missing. However, I only need to use the scanner and am unable to get to the home menu because the error message won't go away. How...
Got a reply from Canon support as below.
During Boot Sequence of the machine, one of the checks performed by the machine is presence of Ink/toner Cartridge and the minimum quantity available in it to start up.
When the machine fails to get the signal of Ink availability, it stops the Initialization Process and an error code is displayed
Since the machine is an ALL-IN-ONE, it cannot perform any of its function, had it been exclusive Scanner the Boot Sequence would have been different.
Jun 18, 2011 | Office Equipment & Supplies
The other day, my wife was using my Acer Aspire One, and set it down for only a minute. When I got back to it, there was a PXE E61 error message. I rebooted the computer, and there was no error message,...
The CMOS battery is the very place and the simplest place to look for trouble. The PXE E61 warning your getting is basically telling you that the laptop cannot read the first boot device and is looking for a network boot device. This maybe from a dead or dying CMOS battery to a loose connection between the hard drive and the motherboard. Change out your CMOS battery, then get back into the BIOS and reset your date and time. After that, perform a virus and malware scan to make sure the system is clean. I recommend MalwareBytes Anti-Malware tool available at www.filehippo.com
If you use MalwareBytes, makw sure to perform a "Quick Scan" only.
After that open the "My Computer" icon and right click on the "C" drive, Scroll down to "Properties", choose the "Tools" tab and click on the "Check Now" button, make sure that the box for "Fix Errors" is checked and click on start. Reboot the system when the scan is completed.
Jul 16, 2010 | Acer Aspire One PC Notebook
Palm unable to read card
Usually you just need to reformat the card to fix it. It may be reable in a pc/laptop so you can get anything important off first. Reformat copy your stuff back on and you should be good to go.
And yup this happens rather randomly and at the most annoying time possible usually ;-]
Mar 19, 2010 | Palm TX Handheld
Scanner not working
Hi Jkey !
As per the information you have provided, I understand that you are receiving an error "No scan option refer to the documentation" on the printer, when you try to print from the front panel of the printer (I mean from the printer's side).
However, plz provide me the proper error message so that I can assist you in the best possible way. If you are unable to scan from the printer's side, then try to scan from the computer and check if it is working or not. It should work when you try to scan from the computer, if not there may be a communication issue between the two devices.
To check the communication perform the below steps:
IF the printer is connected via USB cable, then perform below steps:
Useful scripts For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are able to scan fine using the above steps, please write back to me along with the exact error message.
With Regards
Mike.
Jun 27, 2009 | HP Photosmart 2575 All-In-One Printer,...
When i startup my laptop i get massage that i lost m3plugin
Windows errors related to m3plugin.dll?
If Windows is unable to run applications due to a .dll error, this .dll may be missing or you may have registry error. Such errors can heavily influence the performance of your PC. I strongly recommend that you run this free registry scan.
Here you can download m3plugin.dll free of charge. The file is compressed so you need an unzip software in order to use the file. We recommend you to read the tutorial how to unzip and install the files. Use the link below to start downloading m3plugin.dll.
arrow_w.gif Recommended: Fix m3plugin.dll Errors arrow_w.gif Enhance your PC-speed: Free Performance Scan arrow_w.gif File description: MyWebSearch Idle Monitor, v. 1.0.3.2 arrow_w.gif Filesize to download: 2.4 kb
download_icon.gif Click here to go to the download of m3plugin.dll
Jun 09, 2009 | Intel Motherboard
Unable to create MSXML Instance
First we need to know the operating system installed in the computer.
If you are using XP. Then perform the steps given in the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00516936&cc=us&lc=en&dlc=en
If the issue still persists then search for the file hpqscnvw.exe(scanning file) and then try to scan from there.
Jun 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error Message "Unable to init 46"
error 46: waistink absorber needs replacing. you must have run quite a lot of manual cleaning cycles in case your mfc is about 1 year old....
Feb 26, 2008 | Brother MultiFunction Center MFC-440CN...
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
790 people viewed this question
Ben Johnson
