My aristion DIA 20-24 combi boiler keeps tripping the over heat thermostat button located under the main control panel maybe 5 times a day seems to be getting more frequent
    Scholar:
  • 81 Answers
just check your water supply of your aristion DIA 20-24 combi boiler if is in constant pressure. not properly circulated water supply can cause overheating.
and manuals can help us also in proper checking. at the link below please check this out if you don't have.
http://www.ariston.co.uk/products-select.php?t=0&id=0000000005
Posted on Nov 28, 2008
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Mar 22, 2017 | Water Water Heaters
Combi -boiler tripped out by shower use
Look for a red reset button to press, maybe on top of casing or inside front panel
Mar 04, 2014 | Home
I have an Alpha 240E combi boiler; if two taps are turned on at the same time or say the washing machine is running and someone fills the kettle it trips. Why please? The water pressure is slightly above...
Water flow combi will only pass so much , unless there is a blockage in the water section on your boiler, or water inlet tap is not fully open .
But some combis do have poor flow through the heat exchanger .
Jan 28, 2013 | Desa International GWP20T GLOWARM Wall...
My boiler keeps running even with thermostat removed from circuit. It is a Raypak H1-133A thermionic heating system (pipes in the floor) about 15-20 years old. (thermostat is original, 50 years old).
I answered you previously with information that didn't help. I'm not answering for the $5, but to try to help you. It's been several days and I assume Raypak is not helping.
Possibly the thermostat closes a relay that is on the main control board, maybe this relay is stuck closed. Can you follow the wiring from the stat to the controller? Something in the controller is thinking you need heat.
Gary
Dec 21, 2010 | Water Heaters
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
What boiler?
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 22, 2009 | Combi Centre DX - Mango
When i turn heating or hot water on fuse board trips
it was a faulty heating pump. replaced, all ok now.
Jan 03, 2009 | Honeywell Electronic Programmable...
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
