Latitude Cpi A-series dont boot to bios
Is there any other way of seeing if its going with out pulling it apart thanks
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
May 15, 2011 | Dell Latitude CPI-A Notebook
Need to wipe laptop due to problems laptop
boot from the windows cd and choose recover from the menu then u can choose to format the hdd from there, or if u dont have a windows cd u can download a windows boot disk from microsoft website
Feb 28, 2010 | Dell Latitude CPI Notebook
I have forgotten admin password of bios .i need to change the boot order as first boot device will be the cd-drive
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 10, 2009 | Dell Latitude CPI-D Notebook
Dell latitude laptops cpi cpx won boot up just blinks
If you don't get any fans from the CPU spinning, then there is a problem with actually tripping the power supply in the laptop.
The normal boot sequence is as follows:
1. Power is applied, fans spin
2. CPU receives power and then BIOS is checked
3. RAM then is detected and rest of the system components are quickly checked by BIOS
4. Hard drive is checked for boot sector.
Ask somebody to check the laptop to see if the voltage and amperage from the charger is within tolerance. If it is higher than 130% higher than listed in the voltage or more than 15% higher in the amperage, then the laptop is damaged.
If it is within tolerance, then try removing the actual battery first. If this doesn't help, have somebody check the hard drive. If this boots up in another laptop of the same model, then there is a problem with the transformer in the laptop.
Jul 26, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Password problem
Hi there.
If the laptop was bought for you as a engagement gift and your friend has proof of purchase then Dell will be able to give you the master password as bios passwords cannot be cracked that easily.
Here is Dell customer support site >>>>>>
http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?c=us&cs=04&l=en&s=bsd
Good luck and thanks for choosing FixYa!!
May 26, 2009 | Dell Latitude CPI Notebook
Dell Latitude C600 Laptop
Did you try to boot into the BIOS and load the default settings?
Pls check if the hard drive is recognized in the BIOS first.
Sep 02, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dosplay
Probably have to go to dell and download video drivers for your latitude
Jun 07, 2008 | Dell 20GB NOTEBOOK HARD DRIVE KIT FOR...
Fit a new harddrive in an old laptop
Pls try:
1. When the Dell logo screen appears press the F2 key to enter the BIOS?COMS; or
2. There are some Dell Latitude that uses Fn + F1 (while booted).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Latitude CPI A-Series
log on to www.dell.com and place an online order for a new DELL system
Apr 24, 2008 | Dell Latitude CPI Notebook
Computer won't bootup
help have a dell latitude c800 must have a a email viruse cause it has blue screen with message "beginning dump on physical memory" then it has black screen with message disk error no drive found. did not get a cd for rebooting dont know what to do. it is refurbished and running windows 2000. would appreciate any and all help.
Nov 11, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
