Question about Sharp R-1870 Convection/Microwave Oven
TURNTABLE NOT TURNING AT ALL & ALL ELSE WORKS GREAT!
IS THERE ANYTHING I CAN DO TO CHECK OPERATION OF THIS 6 YR OLD SHARP R1870'S TURNTABLE OR MUST I CALL FOR A REPAIR SPECIALIST??
  • Sharp Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the service manuals for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 28, 2008
My Sunbeam Microwave SGB8901 lights up and seems to be working, but it doesn't heat anything. Is this fixable?
Only 2 years old? Hopefully you still have owner's manual, troubleshooting section should help you look for the problem. Hopefully, there is a circuit breaker, or perhaps a fuse. I hope it was not used with a metal object accidentally. No help? Check with Sunbeam Customer service, be nice, they usually are helpful.
Mar 04, 2015 | Sunbeam Microwave Ovens
HELP! On 12/11/12 I purchased a SHARP 2.2 cu ft stainless steel microwave (order # BBY01-540643080878, SKU# 6035052)for a Christmas gift for my 75 yr old mother...now just after one yr, it's not working...
There is a warranty on all Sharp items. If it is out of warranty by a few days, contact Sharp, not their repairer, ask for advice. You may be pleasantly surprised.
Apr 19, 2017 | Sharp Microwave Ovens
My sharp R1870 microwave/convestion oven turns
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Apr 26, 2010 | Sharp R-1870 Convection/Microwave Oven
Sharp Microwave Lights Up, But Won't Rotate or Cook
Hi. I would suggest checking out the door switches. There are usually 3. If one of those has failed then the microwave won't operate because of safety reasons. Best to replace all three. If the display on the unit is still fully operational I'd say go for the repair.
Mar 18, 2009 | Sharp Microwave Ovens
Our microwave/convecton turns itself off after about a minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
Feb 05, 2009 | Sharp R-1870 Convection/Microwave Oven
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
163 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
