Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Water and Ice does not work. Ice dispenser does not even turn.
Is there some sort of motor that lets the Ice dispenser and water work? Neither one works now. They both just stopped working. I don't think it's a frozen water tube because the Ice Dispenser does not turn and dispense the ice.
  • Anonymous Jul 15, 2008
    I am having the same problem. The little lights come on and my ice is still being made but will not dispense and neither will the water. It doesn't even make a noise. Every once in a while it will work so it seems like some kind of short in something???
  • 237 Answers
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Posted on Jan 14, 2007
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
There is no water coming out of the water dispenser. I changed the filter and check the water line coming from the pipe, there is water coming thru the water line. when I push the water dispenser lever I...
Well, there is no "motor" for the water dispenser, only a solenoid valve. However, there could still be a problem with the solenoid even if you do hear it when its energized. Hearing it make a noise does not mean its working properly.
Aug 13, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
No Water
With out knowing your model of Amana it will be harder to locate the problem. It is rare that both water control valves would stop working at the same time unless you had a crimp or a line blockage feeding water to the refrigerator. First I recommend you turn the water supply off to the rear. Second I want you to disconnect the water feed to the water control valve on the rear near base and lean the line into a bucket so you can have the supply line turned back on just to make sure there is no blockage or crimp in the feed line. Third if you have a self piercing tap valve to supply the water that may be the problem because the hole is small and easy to collect rust or other normal particles in the line. Next you need to check the voltage at the water control valve side for the dispenser. Have someone press dispense water while a voltage meter is connected to the dispenser side female plug. And last of all the door switch may be the only problem. It is designed that when the door is open the dispenser panel is off. If when shut the switch does not make a connection, the dispenser pane, ice maker and auger motor are turned off. Let me know what you find, Sea Breeze
Oct 12, 2009 | Refrigerators
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Dispenser does not work.
Remove the ice tray and clean it throughly with warm water. Let it dry at room temperature and see what happens.
Jul 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Whirlpool side by side GS6NBEXRS01
If nothing is blocking ager .. sounds like motor bad or something binding it up. If you took in out and cleaned all ice out and still dont work with no ice.. sounds like motor ..if it hums power is to motor
Aug 28, 2007 | Whirlpool GS6NBEXR Side by Side...
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
308 people viewed this question
Top Westinghouse Refrigerators Experts
Sal De
Jose Pino
Vincent_G
Vincent_G
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
