Question about Sharp 32F540 32" TV
Rca d52w15byx1 projection 52"tv
Hello my name is joe i have this 52" rca tv (projection) i'm having a problem i turn it on but shuts off rightaway and then back on like four times it will not come on : need some pointers thanks joe c
  • ROSEPEDDLES Jan 25, 2008
    double vision /shadows doesnt mATTER what color every thing has a shadow thanks
  • mgoblue0728 Feb 01, 2009
    same problem here. friend said it may be the bulb, another site said it may be the solder connections. I'll try these, but with the price of new tv's, it may be destined for the recyclers.
    Novelist:
    Champion:
  • 236 Answers
HI, Joe ! You probably have a short somewhere. Where? Possibly in the High Voltage circuit.Maybe the horizontal out put circuit. This is a common signal,especially RCA's, that there is a heavy load on one of the power supplies--- like a shorted transistor or ? Stargazer
Posted on Jan 21, 2007
I have a RCA d52w15byx1 when you turn it on, the power light flashes 3 times then goes out...what could be the problem?
Thats usually caused by failed power capacitors CP150, CP120 and CP114 you can get the RCA CP150 CP120 and CP114 re[pair kit from www.tvrepairworld.com which comes with instructions. That will usually solve the 3 flash issue.
Dec 10, 2011 | RCA P52926 52" Rear Projection Television
Describe your D52W20 52 in. Rear Projection HDTV-Ready Television Problem the tv will not turn on the power light will blink three times then shut off
That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Aug 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv shuts off after 10 minutes model r52wh73
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | RCA R52WM24 52" HDTV Projection Television
Tv does not turn on...u see the red light for 5 seconds then it shut off turn back on for 5 more second then shut off. I was informed the picture tube went bad >> Do u know model name or...
most projection HD TV's do that but it only means to that you need a new lamp look up the model name and you can find the lamp cheap on Ebay or other online buisnesses
Jan 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52" tv was working this morning than shut
Replace the Deflection board. You can get the replacement deflection board from www.tvrepairworld.com
Nov 08, 2010 | RCA D52W19 52" Rear Projection Television
My 52" rca tv will turn on but then after a litle while it shuts off what could be the problem
hi
first you need to check when you turn on tv if the picture is to abnormaly wide this would indicate
a faulty power suply witch triggers the shut down
Sep 28, 2010 | RCA R52WM24 52" HDTV Projection Television
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca big screen, no power light,, dead!
Ck capacitor cp150 2200uf 16 volts if bad 2 more in same circuit also needs to be replaced 220uf 35v.ck second ribbon connector on deflection board make sure it is in correctly,or set will not come on.
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
RCA Projection TV
ok lets begin... shut off? ...is the set staying off. NO POwer at all.. does the set try to come on. does the set have a blinking led on front. have you tried unpluging then waiting 30 min then trying to turn it on again.. this set has a processor and when it detectect any fault will shut the set down
Mar 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sharp 32F540 32" TV Logo
222 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
