Question about Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive
My usb port is broken - Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive
  • forever21 Jan 27, 2009
    I can't plug my printer into the usb connection, I have a presario V5000
  • 47 Answers
Then you need to get it repaired there is no alternative.Contact you company if ur comp is still under warranty else you can contact any comp repair shop.
Posted on Nov 28, 2008
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
Broken USB port
depending on the make/model...you will need to pry open the sides..
slowly along the gap..its got plastic locks holding the two halves together
Jan 30, 2014 | Freecom Mobile Drive XXS 160GB, USB 2.0...
Keyboards doesn't work
sometime windows has some driver error or maybe your usb port or ps2 port for keyboard broken. If your keyboard connect into usb port, please Try into other usb port.
this is because of broken keyboard or broken port. Try using a new keyboard or good keyboard to see the diffrent.
By the way here the other solution link..
Laptop Keyboard Not Working Here What To Do
thanks
Jan 20, 2014 | Computers & Internet
Replace broken usb port on acer laptop
The usb ports are usually soldered to the motherboard, in some cases repair shops can re solder new ones to it but sometimes its best to just replace the entire motherboard. or in this case laptop
Oct 23, 2012 | Acer Aspire 5732z
USB not recognised by the computer
There are few possibilities. 1. You device is broken 2. You usb port is broken 3. Your device was previously installed on different port and now windows cant recognize it on this port.
Solution: Try to plug in your device to different usb slot.
Feb 28, 2011 | Computers & Internet
UBS port won't allow my memory stick to go in is there a lock on it???
Hello !
Be certain you are trying a USB port. It is rectangular in shape. The USB memory stick will only go in one way. Try flipping it over.
If still a problem ...
Either your USB memory stick is bad or your USB port on your notebook is bad.
Try another memory stick or try a different USB port on your notebook - should determine which is OK and which is bad.
Hope this helps.
Oct 28, 2009 | Acer Aspire One A150-1006 Notebook
Broken usb port
if you sure the usb ports are broken replace it..can replace that one. ethier second hand or new... if the device is available.......
Jun 09, 2009 | Computers & Internet
Broken Ethernet Port
You say "your Ethernet Port" (= LAN port)
If unavailable try using any USB to rj45 adapter and you can use any USP port.
Check this device:Linksys - USB200M - Compact USB 2.0 10/100 Network Adapter (20 $?) or similar
Dec 28, 2008 | Linksys Wireless-G Broadband Router
Broken Prong inside connector for mouse
If the ps2 port on the main board is broken you will need to replace the board. If this is the case and your computer has usb ports on it just go out and buy a usb mouse.
If the part that is broken is from the mouse by using tweezers try to gently remove the broken part from the board. if unsuccessful use the usb port with a usb mouse.
Oct 21, 2007 | Computers & Internet
Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive Logo
173 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
