Question about HP Compaq Motherboard
Cd drive not working
My cd drive is not working in my m2vh rh board but it is detecting in the bios and also working in other systems
    Scholar:
  • 83 Answers
Good day! Try to check the jumper maybe its not place properly to where it shud be located? Hp compaq doesnt read if ur installing or cd writing if the lens has faulted. if its working to other applications then try to check the connection.
Posted on Nov 28, 2008
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
Bios does not detect cd rom drives, the cd rom drives has power but it does not work cause bios its not detecting it and it a new drive, my toshiba satellite is a85-s107 let me know if u can fix it.
I have a Toshiba Satellite L355D that would not detect the CD Rom in the BIOS although the Rom appeared to powered up and running. I traced the problem to a ribbon cable connector that was between the jack the CD Rom plugged into and the jack on the mother board. The ribbon cable plug at the MB had backed out and was only making the power connections to the Rom making the Rom appear to be operating.
Dec 05, 2010 | Toshiba Satellite A85-S107 Notebook
My dvdrw is not recognised by BIOS, therefore, not able to boot from CD. Bios version 1.3.
if the drive is not recognized in the BIOS, either the issue is with the drive or your system board. try to remove and reconnect the drive from the notebook. if this does not work, you can also try a BIOS update, or test if your drive will be detected on another notebook. if the drive works fine on another system and another drive also fails on your system, it would be an issue on the system board. If the drive, however, fails on another system, you'll need to get a drive replacement.
Sep 06, 2010 | BenQ Joybook 5000 Notebook
Can't enter window
check you cables from drives to mother board make sure they are all pushed in tight
and check the jumpers are set properly on all your drives then retry if it deosn't work you might need new motherboard or one o your cd or hard drives is faulty
Jul 09, 2010 | Gigabyte GA-K8VM800M Motherboard
Where can I find a driver for my hitachi travelstar IC25N080ATMR04-0
1. You shouldn't need a driver for the hard drive
the Bios ( Basic Input/output system ).
2. You mother board should detect the driver
3. You will have to go into the BIOS setup to see of your hard drive is detect then set the BIOS to boot from the hard drive
4. If your pc takes SATA ( Serial advance technology attachment) then a IDE ( Intelligent drive electronics) will not work with the system without an adapter.
5. Your PC mother board instruction manual will have instruction on hard to access your BIOS settings
Caution: Any changes in the BIOS will not allow some devices attached to your PC to work properly is not properly addressed in the BIOS setup.
Mar 19, 2010 | Computers & Internet
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
I WANT DIRVERS BECAUSE I HAVE LOST THE CD ,MY MODEL NO. FC - QINGHAIHU M2VH-RH ,SO PLZ.SEND THE DRIVERS URGENDTLY,& TELL ME HOW TO INSTALL DRIVERS. THANKS
May 04, 2009 | Foxconn 661FX7MI-RS (661FX7MIS)...
Dvd-rw is not being detected by bios
try the following
1.reseat the odd..u can find the steps at the below mentioned link
http://support.dell.com/support/edocs/systems/ins6400/en/om/parts.htm#wp1076794
2. reset the bios to defaults
3. remove the upper and lower filters
the registry path is
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
plz let me know if it helps so that we can check further possibilities and do rate the solution
Mar 18, 2008 | Dell Inspiron 6400 Notebook
HP Compaq Motherboard Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
