Question about Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic tz3 cover gets stuck
Everytime ive tried to turn on my cam, the lens cover wont fully extend out (its stuck), its never been dropped either. It displays this message " PLEASE TURN CAMERA OFF THEN BACK ON AGAIN" and i do this but it wont fix it. Help!! please!!
    Novelist:
  • 172 Answers
Common problem with TZ3. You can try to lub lens cover using graphite lub. Use it sparingly and after lens works, wipe off excess with dust cloth. Be sure not to get any on lens itself.
If lub doesn't work, you can pull out the lens cover altogether and find a manual lens cap the will fit.
The other option is to sell it on ebay to a repairman in a auction and replace it with another working used ones. Keep your accessories and by a used one cheap without accessories.
Posted on Feb 27, 2009
My camera is frozen. it won't turn on of off and the lens is fully extended. battery is fully charged
your batteries may not be putting out enough voltage for your camera to run on. i suggest buying duracells.
Aug 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
The automatic lens cover on my Panasonic TZ3 doesn't fully open or close.
See my solution to this common problem on other questions from those with same problem.
Jan 04, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi I have a panasonic tz3 camera that when i turn it on it after 3 sec turns to please turn camera off and then on again the cover in front does not open up either any idea?
The cover not opening is a common problem with the TZ3, but this should not cause the waring message. Has the camera been bumped hard or dropped?
Try rapping the camera smartly against the heel of your other hand, or on a harder surface cushioned by a double layer of bath towel. You can also coax the lens cover open with a toothpick.
The error your seeing is common for lens problems, either unable to extend or retraced. Sometime you can overcome these problem by giving the lens or cover some manual help. Otherwise, repairmen on ebay buy them for repair, and working used ones are available on ebay at a good price, likely much better than what a local camera shop would charge you, and much better than what Panasonic would charge you.
If you take the ebay option, you can weigh the option of upgrading tp the TZ5, but the TZ5 is not worth upgrading to if bought new. Don't be fooled with a large pixel figure. TZ3 is a very nice camera to have. I love the wide angle and long zoom..
Dec 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens won't come out
If the camera is powering on as indicated by a normal screen, you can sometimes coax out the lens by rapping the camera against the heal of your other hand, or a hard surface covered with a cushion, like a double with towel.
The idea is to try to free it up without damaging the camers. This problem is common on cameras if dropped or have a few years on them. It is even more common for the Lens Cover on the TZ3 to behave this way. If it is the plastic lens cover that won't open, you can coax it open with a toothpick and if it closes again, I would just carefully pull this plastic cover right out and as a manual plastic cover that will fit the lense.
In any case, it is getting dated by the TZ5, so an alternate is to sell the defectic TZ3 on Ebay and buy a newer TZ5, new or used, on ebay to replace it. Reparmen buy popular cameras like the TZ3 to fix and resell them. If you have everything that came with it, including the box, it is probably worth $40 as is.
Dec 14, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-TZ3 Stuck Lense & No Power
You may be able to free up what is hanging lens by rapping the camera smartly against the heel of your hand, or on a harder surface covered you a cushion of two laps of bath towel. Do not rap the lens itself of course.
If this does not work, you can try puffing a small amount of graphite lube into the two shelled sections of an extended lens and get it to retract and extend a few time. If this works, wipe the extended lens down good with a dust attracting cloth. Graphite lub is used because it does not attract dust, making a friction problem even worse over time, like oil based lub do. Graphite lub is available at any HW store in a small plastic tube made to squeeze, expelling (puffing) a small amount of fine graphite onto a precise locations.
If none of this works, sell your camera to a repairman on an ebay auction, and replace it with a working used, refurb w/warranty, or new one from ebay. Prices are cheap because the TZ3 has been replaced with the newer TZ5, and millions of TZ3s, an awesome camera I own, were sold. .
Sep 20, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic lumix 5.0
The TZ3 has a design problem with their new automatic lens cover, ie, manual lense cap on TZ1 was illiminated on TZ3.
Make sure your lense cover is completely retracted in front of the lense. If not, nudge it fully opened and see if this solves you problem. If it does, contact Panasonic with your problem. If not under warranty, tell them you want them to fix 'their' problem on your camers. Google it on the net and see how common this problem is.
Apr 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Frozen Camera
Try letting it drop about 4 tto 6 inches on a hard service covered by a paper towel. Don't let it land on lens of course. You can remove the mem card. It has 13Meg of internal.
Mar 22, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Refurbished Panasonic Lumix DMC-TZ3
lens cover does not open or close fully. any suggestions?
Jan 28, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
473 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
