Question about Kenmore 56539 / 56532 / 5653 / 656534 Side by Side Refrigerator
Powering off automatically with an alarm
My Regrigerator is alarming me and when i am checking it out, it's powered off. I am unplugging it and then plugging it back again, and it powers up.But again the same issue after a while.I have no idea why it keeps powering off that way. Can anyone assist me in trouble shooting this issue. Thanks, Nicole
  • sam bandla Jan 14, 2007
    I see the lights inside, but it's not cooling and the digital display is switched off.
  • 237 Answers
When you say powering off do you mean there is no electricity at all to the unit? No interior lights or anything?
Posted on Jan 14, 2007
Alarm led indicator wont stop flashing unless i unplug the 12+ wire
Most alarm indicators have an LED that flashes as a theft deterrent. It says "Hey shady guy, this car has an alarm." The 12+ wire is possibly power to the whole alarm (depends on where you're unplugging it), so unplugging it might be disabling the alarm. The light is most likely operating as intended and uses VERY little power so it won't drain your battery unless your car sits for weeks at a time.
Apr 12, 2014 | C3RS727LCD 4Channel Alarm with Remote Car...
Sony alarm clock not powering on
check if battery is ok or not . because when not in use for more days battery will become dead.
Dec 17, 2013 | Sony Dual-Alarm AM/FM Clock Radio with...
I cannot set the clock radio with automatic time set due to daylight savings timem change
I have the same clock and am always able to change it manually with no problems....have you tried unplugging it for a few minutes and then powering back on to see if it adjusts properly?
Nov 04, 2012 | Sony Dual-Alarm AM/FM Clock Radio with...
Aplique alarm 6 14 keeps coming on randomly
The only alarm system I've had is my 12ga with deer slugs.
It shouldn't be too hard to either turn it off, or find the problem power supply. I am thinking the power to the house may have blinked off and on at some point, and the logic of the alarm is freaking out as a result.
Is there a backup battery for the alarm system? If not you could try turning off a circuit breaker at a time until you diagnose which one is powering the alarm system. If you find one that turns the alarm pad off. Leave it off for a few minutes and turn the breaker back on to see if it will reset itself. If the alarm has a battery backup try to remove it and again turn off the circuit breaker. Also search your book for resetting the alarm system.
Dec 01, 2011 | Cars & Trucks
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Alarm beeps every 5 mins. I have changed battery and problem still persists.
Tell me what brand your alarm is and I can help you with the beeping. Usually if you hit # it will silence the beeping for 24 hours. Something you can try is finding your main control box. Its usually located in the garage or in a closet. It is tan and 6 x6. First disconnect the battery inside the control box by jiggling off the black/red leeds. Then unplug the power supply. Wait five minutes. Reconnect the battery and plug in the control box. This is completely powering your system down and then repowering it up-essentially "re booting." If this does not correct the issue, give me the brand and I can further help you.
Nov 22, 2010 | Industrial Home Security Burglar Alarm...
PS-36KX Protection light flashing and alarm.
Check all transistors that are atached to
heat sinks , For a short between two of the
three legs. It can't be reset becuse you have
a short.
Jul 25, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Cannot turn off the alarm
The problem appears to have resolved itself. The oly changes I made to the smartphone was to power it off and insert 16GB mini SD memory card. Since powering back up I have not had the alarm warning.
Nov 28, 2008 | HTC S620 Smartphone
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
Alarm icon won't go away
try to master reset and master clear the phone.
Nov 24, 2007 | Motorola Mobility RAZR V3
Kenmore 56539 / 56532 / 5653 / 656534 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
