C++ problem 1.)accept series of integer inputs & will stop the inputting when a zero is inputted and then it will output the highest & lowest integer & outputs the average of positive even integers. 2.)accept 5 student names,course,year & age and will categorized each if their age: class 1-4- A 25-29 - F 5-9- B 30-34- G 10-14- C 35-39- H 15-19- D 40 above- I 20-24- E negative age - not accepted
  • 23 Answers
I guess this can be done quite easily with stl sort function:
http://www.sgi.com/tech/stl/sort.html
You can also code a sorting algorithm like quicksort or bubblesort yourself. This is quite fun!
Posted on Dec 19, 2008
A hdmi cord was put in hdmi input 3 position and plug into x-box and the tv screen says no signal
Double check the input and that the TV is on that input just in case. But depending on how your Xbox was set up originally the TV and Xbox are not communicating properly. Use your old connected to change the xbox display setting and move the resolution to its lowest, most likely 480. Then reconnect the hdmi to TV and change the settings one by one to see what the highest resolution you can work with. If you choose a resolution it doesn't accept it should revert within a min.
Jul 11, 2015 | Televison & Video
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
How to work a slimline creda nitestore heater
I have one of these heaters as well. The input/output dials are thermostats.
The higher the input dial is set, the more power the heater draws during its charge cycle (ie the "on" period that is set on your time panel). Which means a higher daily ration of heat, and a bigger power bill.
The higher the output dial is set, the more quickly the heater lets the stored heat out. So the highest setting would give you most of your daily ration of heat during the "on" period but less heat for the "off period... while the lowest setting would give you a relatively constant heat output throughout the day.
May 20, 2009 | Heating & Cooling
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
NO volume
often people make the mistake of hooking their devices to the tv using more than one input.  a cable box for example may have many different types of outputs but you are only going to use one to the tv (preferrably the highest quality connection). try switching the inputs on the tv to see if you get the same picture on two different inputs.   If using s-video, you will also need a red & white RCA cable for audio.  The order of video cable quality from lowest to highest is this: Coax(screw on), Composite(yellow,red,white), S-video(Round)+(red,white), Component(video=red,green,blue), HDMI(carries HD video & sound)
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Please Solve this C++ Program
Write a program to prompt the user to input several lines of input. A line of inputs is terminated by '*'. For each readline of input the program should output:(use pointer notation for the array) . The total # of words . The lenght of the longest word in the line At the end the program should output: . The total number of words read in all lines of input . The lenght of the longest word read in all lines of input
Jan 19, 2009 | Computers & Internet
Pls. help me
Q.2#  Dim n, sum as Double
Dim i as Integer
n=100
sum=0
for i=1 to n
sum=sum+1/n
next i
Q.3#  Dim sum as Double
sum=0
for i=1 to 99
if i%2 <> 0 then sum=sum+i end if
next i
Sep 16, 2008 | Microsoft AccRepair DS2 2004 for Fr...
Pattern matching
Nice try!
It's been almost 15 months since you asked your question.
If nobody has helped you with your "homework" assignment,
you probably scored a "zero" on your computer-programming course,
and probably no longer need an answer to your problem.
Sep 12, 2008 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
