Question about Refrigerators
Thermostat clicks on and off but the freezer will not run
  • 108 Answers
It is not the thermostat clicking but the compressor thermal protector. Unplug this unit before the compressor is damaged! You need to replace the compressor starting relay. You can buy a new relay at your local appliance parts outlet. Replacement is very simple.
Ray
Posted on Nov 30, 2008
    Champion:
  • 249 Answers
Faulty motor or relay, thats the overload clicking ,not the stat
Posted on Nov 29, 2008
Will not defrost . Is it a continuous run, 8 hour or 10 hour defrost?
Good day,
It's an 8 hour cumulative running time control. It runs when the compressor runs, and as well the defrost thermostat in the freezer compartment is closed. That's for the running mode, in the defrost mode it runs whether the defrost thermostat is open or closed, and as well whether the thermostat is on or off.
If it's a defrosting problem, it could well be the defrost thermostat, and in rare cases the main heater. They are both located behind the rear panel in the freezer compartment.
In order of frequency of failing,
1. Defrost thermostat
2. Timer
3. Main heater
4. Harness wiring plugs in the freezer compartment that connect these items.
Jun 23, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Chest freezer not used for many years will not run now. Seized compressor? Can this be "unseized?
May be possible but most likely electrical, turn it on for 1 minute, listen for any clicks, turn it off, feel the compressor, if it is seized it will be warming up, if cold the problem is electrical quite likely the thermostat.
Apr 17, 2010 | Amana ABB1921DE Bottom Freezer...
I have a Hoover upright fridge freezer which is not cooling in either fridge or freezer unit, the thermostat control does not click when turned up or down. the appliance is 4.5 years old. model no....
IF THIS IS FROST FREE IT DOES NOT USE THERMOSTAT BUT A CONTROL BOARD. LISTEN TO COMPRESSOR ,IF RUNNING THEN GAS IS LOW(R600a) LOOK FOR YELLOW TRIANGLE ON COMPRESSOR. IF IT RUNS TOO LONG LIKE THIS COMPRESSOR WILL RUN BUT NOT PUSH. ONLY WAY TO TELL IS TO PAY FOR AN ENGINEER TO COME,FIT A VALVE AND CHECK IT. JON THE FRIDGE DOC.
Mar 07, 2010 | Hoover HMA280K Bottom Freezer Refrigerator
My kenmore freezer model number 25329201000 will not run. I was told that it was possibly the thermostat. Can I eliminate the thermostat to see if the freezer turns on?
You can make it come on by running a jumper wire to the two wires that attach to the thermostat. This bypasses the thermostat and causes the compressor to run nonstop. Hope this helps. Good luck.
Dec 03, 2009 | Kenmore Freezers
My admiral fridge/freezer runs a lot but does not get down to temperature
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Freezers
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Food thawed, freezer running. I moved packages from in front of air ways and turned thermostat to coldest setting & it didn't change anything, freezer still at 32-33 degrees. help
Aug 30, 2009 | Freezers
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
hi
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 10, 2008 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Jul 01, 2008 | Freezers
Refrigerators Logo
773 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
