Question about Apple iMac 24" Desktop
My desktop keeps screwing up - Apple iMac 24" Desktop
  • Sean Cole
    Sean Cole May 11, 2010
    Thanks for the concise information!
  • Krabby May 11, 2010
    Screwing up how?
    Sergeant:
  • 367 Answers
  • Rob Houg
    Rob Houg Jan 06, 2009
    Run the items I have listed after downloading them. You should notice a performance improvement. You can also try disk defraging the harddisk as well
    click my computer.
    Right click on C:\ and select properties then tools then defragment now select the main harddisk from the list at the top then click the defragment button.
    Any questions or need more information let me know exactly what is going on.
Cannot seem to get the motherboard out after removing single tray support screw?
Most Dell desktop models use an industry standard mounting screw pattern. To remove a standard form factor motherboard, you must disconnect all cables (very carefully keep track of where all those little ones going to the front of the case go), remove any peripheral cards from their slots (although it is not necessary to remove the memory modules unless you plan to remove them anyway), then search for all and remove all of the screws attaching the motherboard to the base plate in the case. Generally, there are at least six screws: one or two in the peripheral card area near the back of the board, another one or two near the backpanel connectors, two in the memory module area in the middle of the board, another near the front panel connectors, and one by the main power connector. If the board still won't move after you've removed the visible screws, and the drive bracket overhangs part of the board, remove the drive bracket and look for a screw hiding in that area.
Jun 14, 2015 | Dell Precision 650 PC Desktop
I am installing a 250GB HDD in a HP Pavilion a610n desktop PC. What keeps it from sliding toward the back of the case?
A simple screw usually located on the rails sides.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 06, 2011 | HP Pavilion A610n (PC106A#ABA) PC Desktop
I want to upgrade the memory from 2GB to 4GB in my acer r3700-3002. How do I open the case?
You'll find a single philips head screw on the case after removing the foot. Remove the screw and then pry off the side with the power switch using a thin plastic prying tool (I used the plastic packaging from my new RAM, or you can use a credit card). Start prying nearby where you removed the screw - you'll see a small space to insert your prying tool and then keep prying the case open using the plastic and your fingers.
Dec 17, 2010 | Acer Aspire REVO R3700 2GB_DDR3 320G Video...
My acer desktop not work and asking enter password but I forget it.kindly help me
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then
with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a
screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Dec 17, 2010 | Acer Computers & Internet
Help me remove DVD burner for replacement on my Sony PCV-RS720G. Get screws out but something keeps hanging it up and I can't find what it is.
Make sure to remove the power and data cables from the back of the drive.
Sometimes there is a lever or catch of some sort that releases the drive.
Mar 28, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
Remove Dimension 2400 cover to install memory
The cover is normaly one of the side pannel board, u need to look for a screw that would keep it in place(look for a screw that will be afixed on the sidepanel with the back panel, once you have removed the screw just pull the side panel with force using a small hump that u may find on the side/back panel corner.
It's little trickey and need some concentration, u may find the RAM slot on the Motherboard (The RAM slot will be aprox 3 to 4 inch in length, the RAM goes in only in one way...)
hope this helps
Feb 17, 2010 | Dell Dimension 3100 PC Desktop
How do you open the tower of a dimension 2400 tower
If you look at the CPU from the back. On one side usually the left you will see a screw where the side wraps around the back. Some brands will use two screws. Remove this screw and then you can slide the side panel back toward yourself. Then you can turn the CPU exposing the open side. While your in there (make sure the unit is not plugged in) take a can of compressed air and clean your cooling fans and vents. Keeping a computer cool is important to keeping good performance up to where it should be.
Sep 30, 2009 | Dell Dimension 2400 PC Desktop
Remval of power supply from hp d530 compact desktop
there are 4 screws on the back of your computer that will release the powersupply at that point you should be able to just slide it out keep mind were you unplug things
Company site http://www.attechcomputers.co.cc
Jun 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
WIRELESS NETWORKING
Call the Gooksquad back, they screwed it up, get them to put it right.
Sorry but I have no faith in the Gooksquad I spend too much time putting right their screw ups.
Jul 25, 2008 | Dell Dimension 3000 PC Desktop
Apple iMac 24" Desktop Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
