Toshiba wireless problems when laptop looks for a wireless network it finds different ones but cant log into anyone of them ,even when i put in the wep key . in the bottom right tray the icon has a x on the wireless indicater
  • undisclosed Dec 02, 2008
    hello, i have the same problem. using Intel® PRO/Wireless 3945ABG with netgear wireless router. worked flawlessly before with the same euipment. i see networks but it cannot log into them even when i put in the key. plz help
  • James Walker May 11, 2010
    Hello Joshrob my name is James and I'm gonna see if we can fix ya problem, I'm gonna need some more info such as wether or not you have a wireless router or modem that your laptop will be connecting to? if so what type is it i.e. the name of it and who's the manufacturer? get back to me.
  • 2,992 Answers
FWIW I have had that problem on several wireless adapters. They would detect networks but never connect. Or sometimes they would connect but could never pull up any web pages. Something was wrong with the hardware. When an identical card was used with the affected computer everything worked correctly, so it was a defective adapter. You probably have a bad adapter.
Posted on Dec 04, 2008
I re installed windows xp on my old laptop, it didn't install or activate the wireless network adapter, so i cant get online, it's like the wireless card doesn't exsist
Hi, If you re-installed the XP on the computer. You can check if the wireless adapter is recognized. Just follow the steps below:
  1. Click on start
  2. Right-click on My Computer and choose properties.
  3. redmatrix_12.jpgthen click on Hardware tab and then device manager.
  4. Next is on the device manager. look for other devices.redmatrix_13.jpgthis where the wireless is usually located, try to look for Other Devices on the list, and under it there should be Network controller. with a question mark. That indicated that the wireless is not yet installed.
  5. What you need to do is to log on to Toshiba Website to download the drivers using a different computer and you also need a flash/thumb drive to transfer it to your computer.
Hope this helps. THank you for using Fixya, you recommendation is highly appreciated for the free support.
Aug 16, 2011 | Toshiba (PA3212U) Wireless Adapter
No wireless network in range. My wireless network is set to automatic but I am getting the message above when I search for wireless networks. I know there are at least three here.
If you are so sure of three wireless networks in range then it could be the HW problem in the laptop. Is the green light indicating WiFi lighting on? May be your WiFi switch is non functional. So switch on the WiFi and then look for LAN. Login and not searching a LAN are two different problems. If you cant search the wire less LAN then how can you log into any. So it has to be HW problem as you cant locate any although there are three available. So start at the WiFI switch.
Nov 02, 2009 | Dell Latitude D510 Notebook
Need to find wireless security key in order to log on internet. Notebook is finding wireless network. However, I need a security code to be able to log on. Is there a way to find the surity code?
you cant find it without being connected to it.
is there another computer on the network that is working if so just get into the router and look under wireless or security and it will tell you the key.
to access the router on a wokring pc just goto start "cmd" in the run text box and hit run it should bring up a command window that looks something like C:\documents and settings
type ipconfig and press enter
it should give you some info the default gateway is the router so if it says defualt gateway.......: then is router
open internet explorer or other web browser and type or whatever the gateway ip is and hit enter and that should let you into router.
most default passwords on routers are admin/admin or admin with a blank pass or admin/password
Oct 08, 2009 | Toshiba Satellite A105 Notebook
My ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to or .0.1 and log in and chang the settings to default
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Toshiba portege A600 notebook. wireless
unless you have a wireless router in your home; the msg "windows cannot find any wireless networks"
means any network in your area is too far away, or has a signal so weak your laptop is not picking it up as a viable source.
visit . and DL a file called Ccleaner. Run this program - it will clean all your internet caches and junk files, then run the registry cleaner. Reboot.
This can keep you from connecting.
Also try moving to different areas in your home and refreshing your wireless search.
if you are worried your wireless card may not be working properly, take it to a place like mcdonalds, or anywhere that has free wi-fi offered. if you still can not pick up a signal there you have narrowed it down to your wireless adapter.
you can also try this little program. Easy Wi-fi radar found here
Sep 17, 2009 | Toshiba PortegeA600-S2201 Notebook
I have a Toshiba laptop that won't connect to my home wireless system, after I took it to college and used the wireless system there
Does your laptop even see the network? If any security has been set up on your wireless router, you'll have to set up a new wireless connection on your computer. The easiest way to find the settings (SSID, encryption, password) is to look under the wireless network properties of a computer you already have running on the wireless network.
Mar 22, 2009 | Toshiba Satellite A135-S2246 Notebook
Wifi problem with Toshiba laptop
you may need to enable that wireless through control panel
Oct 09, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite limitations on network adapters all wireless, need other
you need to log into the router setting by typing something like 192.168.*.* etc,check the right one for your router and enable some type of encryption like 128bits wep..Then your network is secured with a password which will stop anyone access.Now also change your router password if possible to prevent access from others...Hope this helps.
Sep 06, 2008 | Toshiba Satellite M40-S417TD Notebook
Ethernet controller drivers
go to start/right click my computer/properties/hardware/device manager and look to make sure all signs are + if not you will see a yellow icon..if that so you need to go back to[/support and look for driver (network) controller or chipset
Jul 11, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba laptop wont find router
Right click on the network icon in your task bar or in network connections in control panel and click view wireless networks, then when all the networks show, delete them all and close the window, next, a pop up will say found wireless connections click the pop up icon again and look for your connection in the list and click connect and enter the pass phrase Iif you have security enabled.
Nov 06, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
