Help Please I have a friend giving me a Phillips Magnavox 60" TV. He sent me an e-mail saying this: Takes a few minutes for the picture to adjust but works fine after that. Might need a tube. What do you think is wrong and how much would a new tube cost? Please help me out i'm clueless about electronics and i am moving into a new place this weekend. Should i bother with the t.v.? Thanks so much, Stephanie p.s. e-mail me back at Juicyfruitfla@aol.com
ctf1800
  • 4402 Answers
SOURCE: 60" Philips Magnavox Projection TV Red Screen
You can also check to see if you have bad fluid problems, by looking down in your crt's with a flashlight when you unplug your set and see if you can notice any particles that should not be there. Look at all three and see if there is a difference. It should be clear, if not then you need to change fluid and clean.
It sounds as if one of the picture elements (there are probably 3 for R-red G-green B-blue) has gone bad and it is most likely the green one. Sad to say it will probably cost you more to have it fixed than it would to buy a new TV. Most places will not even look at a TV for less than $85 or so, then they will add parts and labor... if they can even find parts.
Posted on Dec 17, 2007
I bought a crappy old magnavox and rebuilt it. I had both of these issues.
Since your tv is old, the blur problem is probably caused by old coolant in one or more of the CRT lens couplers. Hopefully, the lenses are simply out of alignment, but no one has ever worked on the tv, then this is unlikely.
First, unscrew the back panel of the tv console (should be a bunch of 1/4" hex head screws). There will then be a large white panel at a 45 degree angle held in place by two tabs or maybe even screws. Remove it to see the CRTs. A quick check for the blurry problem is to look directly into the CRTs while the tv is off. DO NOT do it while they are on if you can help it, as it is not good for your eyes.
Shine a white LED flashlight down into each of the CRT's top lenses. Avoid classic incandescent light in this case, since you will be looking for the difference between white and yellow. I you see a white plate inside, good. If the inside looks yellow, and has floating things in it, then the coolant fluid inside is old and bad. You can replace this, but it is a VERY delicate task and MUST be done in certain steps to avoid ruining the electronic boards anywhere within splash zone or drip reach of the lens couplers. The coolant is a special blend available at most tv repair shops, but it's basically clear antifreeze (which you wont likely find in an automotive store).
For the color being off, it is most likely the gain on each CRT being out of whack. First, change all of the user settings (in the on screen menu) for image, color, sharpness, etc to the middle or default.
With the back panel off, somewhere near the bottom of the inside there will be a small black plastic box with wires coming out the sides. This box should have 6 knobs on the front of it (the face facing the rear of the tv); 2 rows of red, green, and blue knobs. These are the screen controls for FOCUS and GAIN. And they should already have some sort of label telling you so.
I placed a mirror in front of my tv so I could see the screen as I adjusted, but you might be able to see it somewhat by hanging a sheet over the front of the screen and looking at it from the inside.
There's a much more in depth method to do this that is described in the service manual (which you are likely to have seen by now; they are usually either stapled to the back of the tv or hanging somewhere inside and easy to see)
But basically, just turn the knobs gently around until the picture looks about right to you. (Remember, if you turn them all up super bright, the CRT will not last very long. Try to keep the knobs near the middle of their turn ability)
If you want to do a full out overhaul of the screen, you'll have to make a lot of adjustments with a bunch of little knobs (variable resistors, really) on the computer board inside. The service manual will tell you what each one corresponds to, but most of them will have a subtle label on the board.
Email me if you need any help
Posted on Mar 23, 2008
SOURCE: Phillips Magnavox 9P6031C103
Yah go to searspartdirect.com and type in the model number the screen is available after market but is authorized for use by phillips it run about $335 dollars if thats to much check local craigs list or tv shops they sometimes have brokes tvs with good screens
Posted on Sep 12, 2008
Ecollier2012
  • 3459 Answers
SOURCE: 60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Posted on Dec 08, 2008
Mastersage
  • 164 Answers
SOURCE: BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Mike
Posted on Feb 18, 2009
I have the same model. My picture is bad my white
If the pic seems dull and the colors are all washed out as well as the tint not being able to be ciorrected to correct tones. Its almost always caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit from www.tvrepairworld.com the kit contains the coolant for all three CRT's and the CD with instructions.
Jul 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
60'' phillips pro
Easy fix....Goto www.TvRepairKits.com and get a chip kit.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
My Philips Magnavox 9P5511C102 color is faded and not clear. The colors seem faded (off) tv is not clear, like is got static, and picture is shaky. I have tried to fix using the Main Menu already. Out of...
update the firmware/software if possible. my 60" has a USB slot on the right side. also you can download the manual from phillips http://www.support.philips.com/support/html/index_us_en.html#../~scripts/xsltransform.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=us_en||mode=cats||item=TV_GR&xsl=subcatalog.xsl
my phillips 60PP9200D/37
Apr 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60" magnavox chassis # PTV843
Hello lagqboy,
It looks like you are having a high voltage problem where one or more of the HV components are failing. The picture starting off small and the growing as the TV heats up is a sign of this (high voltage) problem. The problem experienced when a bright scene occurs is due to poor high voltage regulation. I would suggest that you take this set to a qualified TV repair shop due to the fact that the section I am talking about deals with voltages that can be fatal.
I hope this helps,
Thank you,
Shuttle83
Apr 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips magnavox big screen
That is the service menu code. I forgot the code but you can search it on this sit jou will find it. But be cearfull jou can damage your set.
Apr 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
