Question about Whirlpool AWM8143 Front Load Washer
Whirlpool 6th Sense AWM8123/1 error code FH
The washer has just had new brushes fitted & is now diplaying error code FH - which I understand to be no water in the machine. since the brushes were fitted one successful wash cycle has taken place. The next cycle has displayed the error message - I have managed to get the door open & the washing is wet - any ideas what the problem may be?
Many thanks
    Genius:
  • 1,239 Answers
Hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.thank u....please rate it
Posted on Nov 28, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
My machine won't meter water into machine
When doing inside jobs on the machine see that the power line is off the wall mains. Also note which line goes where before dismantling it.
First try turning off the machine for 30 minutes. Disconnect the pipes at the back top of machine, to see if water comes full flow from your water supply. Check the fine filters on the machine inlet entry, they could be blocked, clean out with old tooth brush. Some filters are removable.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on some washers.
Inlet valves can be purchased thru the net and fitted by you easily.
Water into machines are not 'metered', it is measured by your flow meter inside the machine. A line going up from your outlet area to your panel above to activate a switch, according to water pressure.
Pl click if helped. There are gud videos on YouTube.
Apr 27, 2013 | Kenmore Washing Machines
F h flases
First try turning off the machine for 30 minutes. Still FH? Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Mar 31, 2013 | Kenmore Elite 45986 Front Load Washer
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
Timer display blinks fh on maytag epic front loader
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
FH appears
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3
    Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Our washing machine will not drain, and keeps bringing up "LD" error code. It keeps beeping and the timer isn't going down.
    1. residential washer displays error codes. Though designed to indicate the nature of the error, to anyone without a copy of a washer manual handy, the codes might as well be Martian cryptography. Luckily, the Manage My Life website has partnered with Kenmore and made manuals for each make and model of Kenmore washer available online. The error codes are differentiated between top and front-loading machines.
    2. FH Error Code
    3. When a front-loading Kenmore residential washer displays the "FH" error code, the machine is experiencing a water-inlet problem. A water-inlet problem is the result of the washer receiving too little water to operate. The Kenmore owner's manual suggests five home remedies for this problem: Check that the water faucets connected to the washer are turned on; that the inlet screens in the washer's connection hose are not clogged; that the hose is not kinked; and that the hose is not frozen. If none of these problems are present, turn off the washer, unplug it, plug it back in, and restart the machine.
    4. FL Error Code
    5. The "FL" error code on a top-loading Kenmore residential washer indicates that the machine has over filled. When a residential Kenmore washer is overfull, it will beep every 10 seconds. The pump will cycle on and off every 30 seconds in an attempt to rectify the problem. To stop the pump or restart the machine, either disengage and then re-engage the power source to the washer, or push the overfill reset switch. If water continues to enter the machines after the "FL" error has appeared, shut off the inlet flow faucet or the machine will overflow.
    6. F02 Error Code
    7. The "F02" error code on a front-loading Kenmore residential washer indicates that the machine is experiencing a drainage problem. Home-remedy solutions for this error code, as suggested by the Kenmore manual, are similar to those for the "FH" error code: Insure that the drainage hose is not kinked, frozen, or clogged. If none of these problems are present, check that the hose is less than 96 inches, or 8 feet, above the floor. A hose more than eight feel from the floor will not drain properly
    Dec 06, 2010 | Kenmore Washing Machines
    Whirlpool AWM8143 Front Load Washer Logo
    1,329 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
