Question about Dell Latitude CPI Notebook
When u push the power button down the lights come on for about 2sec i would like to know what it could be if the bios is gone or something i got it off ebay the bloke sead that it was working fine then one day it just stoped could u plz tell me what it could be
  • 734 Answers
Ok, check the processor fan that they will work or not…And then let me know more…
Posted on Nov 28, 2008
    Genius:
  • 2,785 Answers
Plz try by resiting the ram
My dryer will only stay on for about 2sec and then stut off if you wait you can turn it on but again it will not stay on longer then 2 secs. And the light is on when u open the door so there is power and...
CHECK THE PUSH START BUTTON WITH A MULTIMETER. TRY STARTING IT WHILE PUSHING THE START KNOB AND HOLDING IT IN? WHAT HAPPENS? STAYS RUNNING? OR GOES OFF? THE LITES ONLY USE VERY SMALL WATTS SO IF U HAVE A BAD POWER TERMINAL WHERE THE POWER CORD GOES INTO , IT MAY BE AN ISSUE AS WELL CHECK FOR PROPER VOLTAGE AT TERMINAL AND HOUSE OUTLET, LASTLY AND HOPEFULLY NOT UR MOTOR MAY BE ON THE BLINK
Feb 28, 2015 | Dryers
I have a dv9310us. I upgraded to 7 Ultimate, hunted down all of the drivers...it was in prime condition. I then flashed the BIOS with the Vista 32-bit found on the hp site. Now when I push the power...
That is it I'm afraid. The flash was unsuccessful. If you had an antivirus program loaded that will be why it failed. You can purchase pre loaded BIOS chipr on flea bay. All you need to do is find an engineer with SMD knowledge and replace it.
Oct 24, 2013 | HP Pavilion dv9310us Notebook
My playstation 3 will not boot up. When I turn the main power button on there is a red light on under the power button. When pressing the power button a solid green light come for 2sec and a flashing red...
Hi, its not good news im afraid the reason it shuts down and gives you a ref light is due to damage being done to the circuit board inside the ps3.
it could be that it has over heated which is often the case this could be down to dust build up or if the heat sink paste on the gpu and cpu chip has gone brittle or if you have been using the ps3 on carpet or in top of anything else that gives off heat such as dvd or sky box, these cause it to over heat really quick.
right now you have a couple of options if you have any warranty left take it back and get a refund if your warranty has run out then you could try getting it repaired but their is no guarantee the repair will work or how long it will work after the reapir.
as you have got the red light this does mean the console has over heated and their is a fault with the board so its not going to work again the way it is.
now i repair these for 25 quid plus parts so you need to look around if you want it repaired and see what the best price you can get.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
System does not come up
i guess ur motherboard is gone...
also check if can boot from BIOS...do u get the BIOS screen when u press Del/F1/F2 key immeditaly after u switch on...
if yes then ur MB may be ok...else my guess could be correct
Feb 05, 2010 | Dell Latitude C610 Notebook
I have a HP Pavilion a1140n. The computer froze and was turned off by holding down the power button, but it would not boot up. No light appears on the power button, and when it is pushed, the DVD drive...
hmmm strange first thing id try is resetting the bios it seems it has been effected . remove case remove battery leave off for 3 minutes and replace try then again, while u have the battery out hold the power button on , oh and make sure the power is plugged out, and yeap hold power button for 3 secounds just to drain last of power from power supply. hope this helps
Nov 29, 2009 | HP Pavilion a1140n (PX774AA) PC Desktop
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Re: Denon AVR-1100 receiver Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and...
The receiver has gone into a protect mode because something is wrong and it shuts down to prevent further damage. Could be a power supply or output amp issue.
Jun 20, 2017 | Audio Players & Recorders
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Computer won't start
Can you see a green light on located on the mother board ? I had the same problem with mine right after the warrranty was off, The mother board failed, But you should make sure thats it first by making sure everything Inside of the computer is tight and secure.Unplug and make sure there is no power on and unplugged,Before you touch anything inside your computer discharge any static electricity by touching the metal on the inside of the tower. The Memory modules Make sure that they are pushed in securely in there slots and video card is Pushed in and tight, and any other extras you may have plugged into it, After you do all that put everything back and try to reboot see if that get you up and going. If not let me know I can Help You fix it or repair it myself if you would like, just leave message here or email me. bear350cid@yahoo.com Happy Holidays
Dec 15, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Latitude CPI Notebook Logo
46 people viewed this question
Alun Cox
