Question about Motorola Mobility Universal Bluetooth Speaker Car Kit (HF820) Headset
My headset will not work with my new phone.
I just exchanged my new cel phone for a nokia. although I have programed my phone for the bluetooth, and the icon comes on, my bluetooth does not work with it.
0 characters
1 Points
My motorla bluetooth pairs with my cel phone but I can't get any sound. I've tried turning the sound up to the loudest and still nothing. Any suggestions?
Sometimes two diffrent brands will not communicate proper.
Try connect the headset to another phone is it now working?
If Yes --> then I'm sorry but it seems your cel and the headset are not compatible.
If No --> then the problem is most like a technical defect. Go back to your reseller for another headset or let your reseller demonstrate a correct functional headset.
Good Luck.
Aug 03, 2011 | Motorola Mobility Motopure H12 Bluetooth...
I forgort my password and i need it with my new BB cel phone
the password for most bluetooth devices are 0000 or 1234 try both of those i hope his helps you
Feb 22, 2011 | Motorola Mobility H390 Bluetooth Headset
Will a Bluetooth wireless headset work with a normal Blackberry phone, or does the phone have to be Bluetooth enabled?
yes, for you to use a bluetooth headset with any mobile phone, it has to be bluetooth enabled so it can have a means of connecting to the headset.
although, majority of the blackberry phones that are known should work with certain bluetooth headsets since they do not comprise of just simple mechanisms like normal mobile phones. that is just about the same way that iphones usually select special types of bluetooth headsts to work with
hope this answered your question, please rate
Dec 15, 2010 | Just Wireless Bluetooth Headset Wireless...
I need to sync my phone to Nokia CE0560 bluetooth headset - help?
ich habe problem mit meine headset EC 0560 nokia
das kann nicht kontakt klang mit meine bluetooth pc ich möchte wissen was kann ich machen
Mar 21, 2010 | Nokia Bluetooth Headset Headset
I have an I phone and use the Z9i headset. I am
I reloaded the latest software update on the Headset 3 times (each time it said it had been updated and reloaded) finally the last reload did fix the problem. Unknown to me why this worked this way.
Jul 17, 2009 | Blueant Z9i Bluetooth Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Pair my samsung bluetooth to my blackberry cel phone ,
i found out that if you turn the bluetooth off and then turn it back, while turning it back on hold it until solid blue light and then try 2 connect with your blackberry i jus got mine and threw my instructions out. and i did this and it worked and if it should ask for a passcode i used 0000.
Mar 22, 2008 | Eforcity Samsung Bluetooth Headset WEP200...
Motorola Mobility Universal Bluetooth Speaker Car Kit (HF820) Headset Logo
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
