Question about Thorens Audio Players & Recorders
Td-146 part need
Hi I'm from Poland and I'm looking for some parts for my vintage Thorens 146. I would like to know that you can help me to buy headshell tp63 which fit to that model. The other parts that I'd like to buy are: lid (I think td-160 should fit to my one ), and hinges to that lid (I've those hinges contained in chasis).If you could help me let me know
 with kindness regards
    New Friend:
    Problem Solver:
  • 18 Answers
For anything for Thorens turntables from TD-121 through TD-166 go to STS Turntables at Swiss trained and I would trust no one else on earth.
Posted on Nov 25, 2014
  • 131 Answers
hey arr69,if you will go to the site listed above & scroll down to thorens it has many links for parts & imfo(this should get you started in your search)good luck & hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
Hi, Have a Thorens TD147 turntable, have lost the detachable power cord. It is a special cord, possibly used just in that model. Any suggestions
The TD-147 is the semi auto version of the amazing manual TD-160. There is nothing garden variety about these delicate and precise machines. If you really want the correct information or parts for any vintage Thorens turntable, contact STS Turntables at Their tech is mentored and Swiss trained by original Swiss engineers. I trust no one else with my TD-124.
Aug 08, 2011 | Audio Players & Recorders
I need power supply for a thorens td 280 turntable 16vac. where can i order one.
Here's a parts list, but it doesn't link to a supplier.
Power supply for:
TD 520/521/TD 290 II/295 II:
AC-Adapter, Euro standard 230 V
AC-Adapter, UK standard 240V without plug
AC-Adapter, USA standard 110V
AC-Adapter, Japan standard 100V
High End Power Supply for all units with 16/18 Voltage
This is the Thorens Service Warranty link:
This is the Service partners (post warranty) U.S.
Distributor United States:
Address: WS Distributing, LLC
3427 Kraft SE
Grand Rapids, MI 49512
Phone: +1 616-885-9809
Fax: +1 616-885-9818
Email: tmyerswsdistributingcom
This is the Thorens Homepage Technical Database for the TD280
Downloads are NOT free.
Someone there should be able to help you out.
Dec 31, 2010 | Teac Audio Players & Recorders
Hi I have an old but beautiful Philips radio nr 22RH752 purchased around 1977. It still works ok but one of the music box outlets in the back does not work anymore. I have a feeling it is only a small...
Hi Tjonker.
Did you fix the problem?I live far away from you(Poland) but still seek schematics or service manuals.
Is it posssible to get from you.
If you don't fix please let me know more and I can help.
Regards Tom
PS Collect beautifull vintage Philips.Have 12 of them.
Sep 10, 2010 | Audio Players & Recorders
Bought a TD 150 MkII that runs 100 ~ 240 volts 50 Hz. In my country we have 60 Hz. How to correct ?
It's simply a matter of if the transformer can take the 60 Hz. After that the supply passes via a large electrolytic capacitor which is there to take out the 50 Hz. Otherwise you get a hum, which is what happens when the large capacitor fails.
Though I can not be certain! It might just work with the 60 Hz without doing nothing. Though if you get a hum you might need to replace the big capacitor with one with a greater value than the one in. Say the one you have in is 2200uf at 50v, you would need to replace it with 4700uf or higher at the same voltage or higher. Of course the other problem might be getting a bigger capacitor in!
Jan 11, 2010 | Thorens Audio Players & Recorders
The tone arm of my Thorens TD 160 need adjustment
My advice to you would be go to a hifi forum on the web. I'm sure they will point you in the right direction.
Jan 11, 2010 | Thorens TD-170 Turntable
I have a Thorens TD115. The left channel doesn't
I am basing my findings on my THORENS TD166 MK2.
First thing you have to do here is check the wiring from the headshell to the RCA phono leads - for this you need a multi-meter set on continuity.
Disconnect the cartridge and put one meter probe on one of the headshell wires and the other to the centre pins and outer rim of the RCA plugs. One headshell wire should read fine on one part of the plug as it will correspond with ONE part only of the RCA plug. When you have checked all wiring and you get a continuity check (OK) then you must look to the cartridge.
However, if you get a reading of ONE headshell wire reading more than one part of an RCA plug then you may have an internal wiring problem in the deck.
Here is something that might help:
RED - to centre pin of right output plug GREEN - to outer metal rim of right output plug WHITE - to centre pin of left output plug BLUE - to outer metal rim of left output plug In some cases this wire may be black
Just to recap, if these readings are OK - the cartridge may be at fault.
I wish you well with it!!! (:-)
Sep 25, 2009 | Thorens Audio Players & Recorders
Need new lid for Thorens TD 160 turntable. Any ideas where I can get one from
I can't guarantee anything, but look up and call Stereo Component Systems in Boston Ma. When I was there, they still had quite a bit of Thorens parts available.
Sep 08, 2009 | Thorens Audio Players & Recorders
206 people viewed this question
Top Thorens Audio Players & Recorders Experts
Ben Armstrong
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
