The monitor doesn't turn on, but the power stand by light comes on
  • 2 more comments
  • zgheist Nov 28, 2008
    computer works fine
    its the monitor..its like the screen just stopped working
  • Yogendra Kumar
    Yogendra Kumar Nov 28, 2008
    monitor light blinks but not shows any thing helpp??
  • zgheist Dec 05, 2008
    no, nothing is wrong with the computer tower
    NOTHING
    its all in he monitor
  • Anonymous Jan 18, 2009
    My monitor light nor my monitor comes on. It was fine and I moved the monitor around on the desk and it will not come on now.
    Does the cable that comes out of the computer be eaily replaced?
  • 734 Answers
Sum beeps comes at startup your computer then check your CPU RAM.
and then tell me again,, is that work.
Thanks
Posted on Nov 28, 2008
  • 1 more comment
  • futureloginn
    futureloginn Nov 28, 2008
    yes, i'll understand your problem but as i says--- sum time due to sum Loosing in RAM of your computer,, the monitor dos not shows any display....
    I want to know more about your problem ........
    tell me that your CPU loads the operating system or not??
    To check your problem is in monitor or in CPU connect another monitor to your computer.
  • futureloginn
     sum time due to sum Loosing in RAM of your computer,, the monitor dos not shows any display....I want to know more about your problem ........
  • futureloginn
    futureloginn Dec 05, 2008
    ok,
    than the fault is in the cable connected to cpu. you need to replace them.
    Thanks
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
Do not turn on. Power failure. Replaced all the electrolytic capacitors, but still does not work.
good day check if their is a stand by 5v voltage at the power supply and a light indicator on the front panel. now if no stand by voltage and indicator light the problem is with in only at power supply. check for shorted mosfet transistor and bad regulators. now if their is an stand by voltage but doesn't turn on check the inverter board and back light for shorted parts because the main board will not turn on. check also for bad processor. hope this will solved the problem thanks for consulting the fixya.
Aug 09, 2011 | Televison & Video
I press the power button it lights for a second then turns off screen does not come on
Doesn't sound good this sounds like the monitor it shot or the video card is shot If you have another monitor try it ad see if the video card is still working if it does the same thing then it is not the monitors
May 24, 2011 | BenQ FP92G 19" Monitor
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Why is my computer turning it self off
Most probably you have power management set to go to stand by after some time. Go to control panel, click on power options, and where it says system stand by set it to never, and turn off hard disk to never, and the turn off monitor you can set it to your needs, for example, I have mine for 20 minutes.
Sep 01, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My monitor is not working
First, stop to realize that some monitors are powered through the cable that comes from the computer stand alone unit. Some get power and have a normal electrical receptacle in the rear of the monitor. Some monitors have a little hole for the installation of a small plug from a step down transformer. Kind of like the one use in cell phones. If you have any lights on the monitor....then it isn't the power. If you do, then replace the cable from the stand alone to the monitor. Or, if you have another monitor, try it with your stand alone. But, most trying to help you are RIGHT. Details, you might wish to give more detail to get an accurate effort from this support page. Good luck.
Dec 30, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
