Question about Denon AVR-3801 Receiver
No dolby digitaL ON BLU-RAY FIMLS played thro a ps3,
When i play blu-ray films thro my ps3,it wont come up as dolby digital,just prologic digital??? yet put a game on the ps3 and it comes up and locks onto dolby digital,im so confused with this ,Denon AVR-3801 7.1 Channels...
this happens all the time with normal dvds that are 5.1.dolby digital..
im wondering if its the platstation 3 capabilites,,can anyone help
  • 1 more comment
  • stephenchamb Nov 28, 2008
    OK many thanks for that, just not the same when the speaking comes out all the speakers instead of the center,its constent and not split up the like i get on dolby digital..Sorry forgot to add i have full 5 speaker set up,well 6 with the sub,,,one more thing ,whats neo 6 , i can put that on and it sounds not so crowded if you no what i mean...cheers steve
  • sherris Jan 12, 2009
    My ps3 also will not play Blu ray's in dolby digital . Ps3 games and Normal Dvd's play in dolby digital 5.1 with no problems.The sound is much better playing dvd's than it is when playing Bluray.
  • Anonymous Feb 07, 2009
    MY PLAYSTATION 3 WILL PLAY GAMES AND DVS IN 5.1 ON MY CINEMA SURROUND BUT NOT BLUE RAY DISCS
    Genius:
  • 1,066 Answers
Prologic is a form of dolby digital, the 4.0 or 5.1 (versions I and II respectively) to be exact. the type of dolby version is determined by the source disk. the reciever may expand a dolby digital signal into 7.1 but it is actually a 5.1 standard, as is prologicII
Posted on Nov 28, 2008
How do I install my Philips BDP2100 Blu-ray player
Why do you want to install the blu ray player you Xbox one can play blu Rays I would bother connecting the blu ray player at all
Nov 22, 2014 | Philips BDP2100 Blu-ray Disc Player -...
Our new lg 5.1 surround sound system will only play full surround sound on some new release blu ray films and the rest will only play through the front 3 speakers as dolby stops as soon as you get past the...
Dolby will only activate when it has information for all 5 channels. For normal stereo only left, right and bass boost speakers work, so you lose center and rear speakers. The system should have an option to play SIMULATED surround sound, to activate all speakers. In many systems, this option is called dolby prologic, simulated or some other fancy name.
Jan 17, 2010 | Audio Players & Recorders
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
My ps3 has just started to stop playing blu ray films after 20min
the laser is starting to go bad in the dvd drive. It takes more power for the drives laser to read and play a blu ray movie then it does to play a dvd game.
You can either replace the laser if you have the technical knowledge to take the dvd drive apart, or just replace the drive. You can usually find either one on ebay.
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
PS3 DOLBY DIGITAL ISSUES
In the PS3 menu, open Settings > Video Settings > BD/DVD Audio Output Format (HDMI) or (Optical Digital) depending on which one you are using. Set the type to to Bitstream (Linear PCM does not send the DD stream through).
Oct 23, 2008 | Sony Playstation 3 (PS3) Console
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Denon AVR-3801 Receiver Logo
1,090 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
