Question about iRiver H10 MP3 Player
Connection issue with usb
When i plug the device into the computer and turn it on it say usb connected then within 10 seconds it says OK to disconnect. Cannot get it to stay connected. Any ideas
USB can be finicky. First try switching ports. If you are on a USB hub, try connecting directly to the computer. If you are using front access ports, try switching to rear ones. Next try switching to a different USB contorller. IE if you have different controllers on your motherborad or some of your usb ports are on a PCI or PCMCIA card try switching between these. Finally update the drivers for your USB controller if none of the previous steps have worked. Usually these don't get updated very often, but have your computer search Windows update or go to the manufacturer site just in case. Try it on another computer just to be sure that nothing is corrupt with your Windows installation or set up. If you still have no luck you likely have a damaged cable or a dirty or damaged port on the player. Try cleaning the connection port on the player. If the cable is to blame, you can purchase a dock for the H10, though they are very hard to track down these days.
Posted on Jan 23, 2007
SOURCE:
How do i enable a disabled iphone 4s that shows iphone disabled connect to itunes?
Hold the power button and home button until the phone restart when it restarts hold the home button only for 10 seconds and plug in your sync cable it should connect to iTunes
Jan 08, 2016 | Apple iPhone 4S
No power , computer will not turn on
Hi, IF the system is not turning on any more, try removing the power cable, then press the power button for 10 seconds. then try to power it on again . If it is still not powering up there could be an issue wiht the power supply of the computer. But if it start to turn on, like showing the Sony logo then windows but not going to the desktop. you can try to log on using safemode. you can go there by pressing F8 on the keyboard after turning on the computer. If it still not turning on even on safe mode. there couldbe an issue with the operating system of the computer and needs to be reinstalled.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Aug 20, 2011 | Sony VAIO V2M (VGCV2M) PC Desktop
Blank/black screen when i turn on the laptop
Please try the basic troubleshooting steps to resolved the issue:
- Disconnect all external device (example: USB Flash Drive, Printer, external hard drive, etc.) - Turn off the computer by pressing and holding the power button until all lights turned off. - Disconnect the ac adapter from your computer. - Remove the battery, wait for 10 seconds, then connect the battery back. - Plug in the ac adapter. - Turn on the computer.
Hope that helps.
Apr 17, 2011 | Dell Vostro 1510 Laptop
My acer mouse model number mg-0919 stops working after about 2 minutes. I have to turn the mouse off then back on. This happens constantly. What is going on? Is it defective? My mouse is under...
I had the same problem. This mouse came with my Acer Revo which was still under warranty. Tech support basically says to check the obvious (batteries, USB connection, RF interference). Their obviously canned answer goes on to detail a manual reconnect procedure that does not apply to this model. And when all else fails, get a new mouse.
This is what Acer tech support emailed me:
If you are experiencing issues with your wireless mouse not working properly, perform the following steps to troubleshoot the wireless mouse.
1) Ensure that the receiver is 8-inches from other electrical devices. Avoid placing the cordless devices on metallic surfaces.
2) Verify that the USB connector from the receiver is properly plugged into a USB port on the computer. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
3) Remove the batteries and then reinsert the batteries into the mouse, making sure that the battery polarities are correct.
4) Test the batteries to ensure that they still have a charge.
5) Try the manual connect procedure.
Manual connect procedure:
1) Press and release the Connect button on the receiver.
2) Within 30 seconds, press and release the Connect button on the mouse.
If the issue persists, we can replace your computer's wireless mouse.
We will ship the new wireless mouse within 3-5 business days.
Before placing an order for wireless mouse we would like to confirm the following.
1) Complete shipping address:
2) email address:
3) phone number:
In order to place an order for wireless mouse, the computer must be registered.
Oct 06, 2010 | Acer Aspire One PC Notebook
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
Sep 24, 2010 | Office Equipment & Supplies
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
Hp all in one
Try the follwoing steps, i m sure that it will start working bcoz i tried the same steps and my printer started working:
  1. Turn the power to the computer off.
  2. Press the power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If the issue is not resolved , try some other troubleshooting:
  • Connect USB cable directly to the computer and then restart the product and try to scan again
  • If the product still does not work , try some other steps:
  • Connect the USB cable to a USB hub or a docking station for a laptop. 1. Restart the computer and the product and try to scan again.
  • If the product doesnot works after connecting the USB cable directly to the computer , follow these steps:
      1. Reconnect the USB cable.
      2. Try the scan again.
        • If the product worked when the USB cable was connected directly to the computer, but does not work after reconnecting the USB cable in the original configuration, there might be a problem with the hub or docking station. Either leave the USB cable connected directly to the computer, or contact the manufacturer of the hub or docking station for troubleshooting.
      If the product does not work after connecting the USB cable directly to the computer , follow these steps.
      1. Replace the USB cable.
        • If the product does not work with the new cable, continue to the next solution.
    Now, if this doesnot work, there is a conflicting USB device connected to the computer
    1. Disconnect all other USB devices from the computer except for the keyboard, the mouse, and the product.
      • The issue would be resolved now and teh answer is that the computer might not have sufficient power supplied to the USB ports to detect multiple USB devices. HP recommends installing a USB powered hub to connect multiple USB devices.
May 28, 2008 | HP DeskJet F380 All-In-One Printer
When i connect my hard drive to my laptop the baloon comes up saying that usb device is unrecognized.
SYMPTOMS: loadTOCNode(1, 'symptoms'When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
To work around this issue, use one of the following methods:
Method 1 loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2 loadTOCNode(2, 'workaround');After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 4 loadTOCNode(2, 'workaround'); Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties. b. Click the Power Management tab. c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.-------------------------------------------
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 29, 2008 | Computers & Internet
iRiver H10 MP3 Player Logo
43 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
