Question about GE 25GT270 TV
Turns off by itselt, now won't turn on
The prob started initially by the TV turning off by itself. It would take anywhere from 5 mins to 45 mins to be able to turn back on; the time it would stay on would also vary. Now I cannot turn it on by remote or manually.
  • tysonsmomii1 Nov 28, 2008
    Did not see standby light; unsure of what your terminology means, i.e.: oscillation circuit and starting capacitor in the "hot" area.
  • 790 Answers
Hi
did you see the standby light? in this case you said 5 to 45min. before the unit turn back on, this needs to check the oscillation circuit or the starting capacitor in the Hot area...
Thanks...
Posted on Nov 28, 2008
  • carlos fernandez Jr.
    carlos fernandez Jr. Nov 28, 2008
    ok sir if no standby light your unit needs to Diagnose by a qualified technician Because this is have problem in the power regulator.
    Thanks!
Will not turn over but after about 5 to 45 mins wiill start up perfectly.
When you try to crank the engine, are you hearing any response at all from the starter? Click from under the hood? Dimming interior lights? Anything?
Oct 30, 2013 | 2001 Saab 9-3
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Mar 15, 2010 | Samsung PN50A400 50 in. HDTV Plasma TV
Initial setup on Bravia 26" won't come up
Try resetting the TV to the original factory settings. After resetting the TV to the original factory settings, you can get the initial setup screen to select Antenna. Make sure that the cable from the Antenna is connected to the TV.
Follow the steps given below to reset the TV to the original factory settings:
(i) Turn ON the TV.
(ii) While holding down the Up arrow button on the Remote control supplied with the TV, press the Power button on the TV set. The TV will turn itself off then back ON again.
(iii)Next, release the Up arrow.
Sep 08, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Mitsubishi WD-62528 error code 45
go to the manufacture site they should tell you what the code means if not try techlore.com
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Turns off/ on by itself model 27v412t
well my tv was doing the same thing my prob was the buton bord.the ezyest way to check it was to take the back off and find the wires that come from the boton bord the plug the tv in and turn the tv on wile its on unplug the boton bord wires if the tv stays on that is probly your prob the bord dont cost much I found a site on here that has them for under $5.remember to be carefull when checking it out tv car be very dangerus.I found that if I beat on my buton bord alittel it would work for awile hope this helps
Oct 26, 2007 | RCA 27V520T 27" TV
Tv turnitself off and on at will
This sounds like a power supply problem possibly a bad capacitor
Jun 19, 2006 | Quasar SP-2023D 20" TV
GE 25GT270 TV Logo
87 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
