Question about Durabrand DWT1905 TV
The word "Factory" is in red at the top of my TV screen. I've already tried turning it off, unplugging it, and also pushing every buttong possible on the remote. How do I get "Factory" off?
  • Anonymous Mar 29, 2008
    i have a durabrand tv bh2004 and i can't get the red word factory off my screen?
    Novelist:
    Champion:
  • 236 Answers
You might try pushing two buttons a once. Like volume up&down or channel up&down. Do this from the control panel on the TV not the remote. I've seen this happen on some sets,but I'm not sure about your brand.
Posted on Jan 21, 2007
My 32 inch element tv when i push the power button its red then turns blue but no picture
How old is it? TRY this.. Hold down the menu button on the top or side of your TV for at least 10-15 seconds. An on screen menu will appear asking you to enter the time, date and location settings. Follow the onscreen instrucitons, and once completed your TV will reset to factory settings.
Feb 02, 2017 | Element Televison & Video
My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
Aug 30, 2012 | Televison & Video
Mitsubishi WS-5541 light blue glow
I know these sets pretty well--worked on a lot of them when new and later--one of two possible ideas=
1. Either a odd convergence problem==confirmed or denied by going into the convergence menu (in customer menu) and selecting advanced which will bring up a grid of lines--if see the same issue (I will attach a photo of a Mitsubishi with this problem) it can be fixed.
2. Some sort of issue with the circuit board on the end of the Blue tube(you are missing blue=black) but usually in this set if that happens it is uniform and on both sides of the screen, not the top.
Let me know what you find.
I doubt it is convergence, but does not hurt to look--if the missing area was perfectly rectangular I would suspect up/down centering adjustment.
There is one other possible thing to try--we will leave it for last--set has 3 hidden menus and one is OPTION menu which allows a hard reset of entire set--sets everything back to factory except convergence adjustments which are stored in another area.
Apr 06, 2012 | Mitsubishi WS-55411 55" Rear Projection...
Red screen
Are you talking about the "Red Screen Of Death"? There isn't to much you can do about that other than possibly changing out the Hard Drive to see if it is a corrupt file or other defect with the actual hard drive. The red screen is usually overheating of a unit because they don't a built in cooling system. Some steps you can take are.... (some you've probably tried already)
1. Turn the unit off and completely unplug it for about 30 minutes then try it again.
2. Take out the hard drive and re-insert it. Make sure all internal connections are still tightly connected.
2. Try inserting a different hard drive from a friends unit to see if it works. If it does you know it is your hard drive.
Feb 23, 2012 | Sony Playstation 3 (PS3) Console
How to reset sony kv27V42 to factory settings ?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 22, 2017 | Sony KV-27S42 27" TV
The other night I inserted a DVD and it played beautifully. When I switched back to watch cable TV, the screen had a red tint. I've tried unplugging the screen and checked the video cables. Still...
The problem sounds like it is with the Light Engine, I would contact Customer Support for help, possible repairs. Thank you for using FixYa!
May 27, 2011 | Televison & Video
We've had a 42"
Sounds like the powersupply is bad. Try replacing that. Hope this helps.
May 25, 2011 | Televison & Video
We've had a 42" LCD/HD
Tries tv unplug,replug it back like about an hour later.Most of the times tv will resetting itself back to the factory setting and will work again.If still have the same problems,tries pushes the power button on/off a couple times for trying to fire up the tv Tuner signal board,these off/on tries work with many LCD/Plasma HD tvs.But this kind of problems,eventually u have to change the tv Tuner signal board sooner or later.Because the tv Tuner signal board it is dying,and this solution is just a temp fixed for the delaying it for awhile.
Red vertical lines on my laptop screen
Hi. Try to drain the electrostatic energy of the motherboard and see if this can resolved the issue. Please see procedure below.
Take out the battery
Unplugged the power adapter
Push and hold the power buttong for 30 secs
Put everything back in
Power on the computer
If same issue happened after this troubleshooting. You need to contact your computer manufacturer and have it repaired. Pissbile LCD problem or wires connecting from LCD to motherboard is having the problem.
Jul 25, 2010 | Dell Computers & Internet
Durabrand DWT1905 TV Logo
247 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
