Question about Bosch Washing Machines
Crunching sound at the commencement of spin cycle
Our Bosch Maxx 900 front loading washing machine crunches at the beginning of the spin cycle or when changing direction. Its like the sound of marbles rolling in the sealed unit behind the stainless steel drum. Could it be a broken drive or gears? Appreciate any suggestions as to what it might be.
Thanks
Michael
  • maeasey Nov 28, 2008
    Hi abhishek33,
    Thanks for your prompt reply.
    I've already removed the back and the belt looks OK.
    I haven't checked the pulley however. I'll do that next.
    Regards
    Michael
    Genius:
  • 1,239 Answers
Hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Posted on Nov 28, 2008
I have cleaned the front filter but machine still won't drain water?
from your description, it sounds like you have a water stuck water pump. The crunching sound is probably foreign objects grinding againt the pump blades.
Aug 12, 2014 | Washing Machines
We have a Bosch washing machine E-nr wet2820GB / 13 FD 8101 0017. Recently it has started making an unusual, very loud 'crunching' noise during the wash cycle, it then stops on 'main wash',...
There is a clutch that gets dry and sticks it has to be greased from time to time.
It sounds like the clutch cannot slide on the spline and is causing the issue at hand.
Aug 01, 2011 | Washing Machines
My washing machine won't turn or spin.
ok on the bottom there is a donut looking connector with holes and it needs replaced unless its belt drivin
Aug 14, 2009 | Washing Machines
Kitchenaid dishwasher makes a crunching sound during rinse cycle
Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
Gibson front load washer will not spin
well lol thats what i was going to tell you to do if you didnt hear the crunching sound with the power off but good for you
Mar 28, 2008 | Washing Machines
Washing Machines Logo
551 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
