Question about Lands Phones
I Have a PANASONIC TELEPHONE REF PQLV 300322A and it has started to flash an aerial icon at the bottom left ahnd side of the screen.Also,when I dial a number it beeps four times.I have tried taking out the batteries and plugs in order to re-boot the set up but with no success.Please can you help. Thank you David domakin
  • 62 Answers
Clean your phone lucker tinner..
i think it had a shorted area!!!!
thans..
Posted on Dec 08, 2008
Panasonic phone no dial tone. Picture of telephone pole on screen. What's going on?
Have you confirmed that you have a good connection at the base unit by plugging in a regular corded phone?
Dec 01, 2014 | Panasonic KXTGA470S KX-TGA470S KX TGA470S...
At work we have a panasonic kx-t7668 telephone. I have followed the instructions on (one-touch dialing), but now when we have incoming calls in the office i dont have a red light that flashes at me, so i...
Did you do something stupid like program over the top of the buttons? Press PROGRAM and, starting from the bottom press a button, then dial 0 01 STORE Move up the line and press 0 02 STORE etc. Do that for however many lines you have and it puts the lines back into the Single-CO sequence that you probably started with. (PROGRAM is done from an idle phone and you press PROGRAM to exit).
Carl
Apr 01, 2011 | Panasonic Lands Phones
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 20, 2011 | Watches
How to set a new CO num into kx-t7730? screen is appear "CO not assigned"but the line already plug in .
In analog system like the KX-TA series, the lines have to be both installed and programmed to a set. System program 400 sets the lines and pressing PROGRAM, a CO button on the left side of the phone and dialing 0x STORE sets the line on the telephone.
There are also some access and ringing programs that need to be done in system programming and they are located in sections 407-412 or so.
For example, if you added line 3, you would go to 400, make sure that CO 3 is enabled, then press PROGRAM on each phone and the 3rd button up from the bottom. If the display doesn't say "CO3", then you dial 03 STORE and that will set line 3 on the phone.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
How do I connect to another WII on the internet
you have to register each other by exchanging friend codes (you both have to have each others friend code) you do this by on the wii menu you click the icon on the bottom left ahnd coner and got to address book and add a contact
Nov 13, 2009 | Nintendo Wii Console
My Panasonic Telephone Model KX-TSC35JXW dial pad is locked
I am having a Panasonic Telephone Model No.KX-TSC35JXW but I am not able to make calls because it is telling that the dial is locked but i dont know how to solve the problem.Please help me.
Jun 22, 2009 | Panasonic Lands Phones
How to disable dial lock without password
I am using panasonic PANASONIC KX-TG2620BX and was locked by my daughter. We had it unlocked by:
press MENU
select Dial lock
Enter password 1234
Press save
Turn off Dial lock? press yes
Jan 08, 2008 | Panasonic 5.8GHz Cordless Telephone
Lands Phones Logo
81 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
