Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
Honda 5.5 hp air comp. no spark wont run
I have a Ingersoll Rand air comp. w/ a Honda motor GX 160, pull start ignition system, engine wont run. No spark ,
  • 1205 Feb 12, 2009
    hi i have honda 5.5hp it had no spark, i change the coil now i have week spark does any anybody know the gap setting for the coil between the flywheel & coil please thanks marc
    President:
  • Honda Master
  • 1,388 Answers
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Posted on Nov 29, 2008
The air gap for Honda GX160 is 0.016(+-0.008) inches or 0.4mm(+-0.2)mm. Insert a long thickness guage between the flywheel and ingnition coil. Both gaps should be adjusted minullaneously.
Posted on May 04, 2009
  • 26 Answers
I use the spark plug box as a gap setting...it was a general-nonspecific setting...so far it work well on all machines...
Posted on Aug 22, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand en6f75 compressor. Does it have to run in a particular direction as I cannot see any direction arrows on it.
We provide tech manuals for all of our products at www.irtechpubs.com. We also supply technical information on our website www.ingersollrandproducts.com. Hope this is helpful.
Ingersoll Rand Employee
May 13, 2011 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand 30, srats for 20seconds then trips breaker,,,runs great when running
Sounds like the unit is pulling to many amps during start up. Possibilities are: breaker under sized, wire under sized, to long of a run of wire from breaker for wire size,Tank check valve bad. I would check the amps during start up and while running and compare to motor name plate information. Remember at start up the motor may pull 1.5 to 2 times the rated amps on the name plate. Also if this unit has a magnetic starter wire connections may be loose or overloads to small.
Dec 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
I believe that the motor starter circuit on my Ingersoll Rand 2475 5 hp 80 gallon compressor is incorrect. It's a 30 amp single phase compressor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
Nov 14, 2010 | Ingersoll Rand 2340/2475 Electric Air...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Ir 7.5 vert 80 gal comp,..works and works good,...but upon startup,,motor sparks,....whats up with this?????
Same as all my 220v compressor motors. Contacts make and then enable (maximum) start-up current inside motor (brushes). Only flashes for a moment....startling yet normal. Hope this helps!
Jul 12, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
5,660 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
ray gallant
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
