Question about Kenmore 45081 Front Load Washer / Dryer
No power in dryer
There is no power to the dryer...and it is plugged in, and no fuses are blown. It was working perfectly and then, there was no power.
  • 641 Answers
It sound like a disconnected wire problem. Goog luck !
Posted on Jul 26, 2007
The power blew while it was on with the dryer
check the hv capacitor for a short and fuse, if thats not the problem call electrician, sounds like a bad breaker
Feb 04, 2010 | Magic Chef CMV1000B Microwave Oven
Dryer
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Jul 23, 2008 | Kenmore 63942 Dryer
My dryer wont do a thing. it wont even make a noise. its plugged in. do i have to buy a new one. its a kenmore 80 series
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Jan 02, 2010 | Maytag Performa PAV2200
Whirlpool sport dryer wont start lights come on when you push start button sounds like its activating but wont start is it aproblem with the button not sending the right signal
Door switch
Thermal fuse
Wiring
Aug 04, 2009 | Dryers
Dryer will not run at all. It seems to have power going to it though. Any thoughts?
Door switch
Thermal fuse
Wiring
Jun 14, 2009 | Maytag Neptune MCE8000AY Electric Dryer
The dryer won't start
Door switch
Thermal fuse
Wiring
May 31, 2009 | Dryers
Will not start
Door switch
Thermal fuse
Wiring
May 20, 2009 | Dryers
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
Door switch
Thermal fuse
Wiring
Apr 01, 2009 | Kenmore 63942 Dryer
This is the 2nd time my dryer in 1 year just stopped working and last time it cost me $100
http://www.repairclinic.com/0088_8_1.asp#Level1_1
Door switch
Thermal fuse
Wiring
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Dryer
your thermol fuse is blown .
Sep 10, 2007 | GE WSM2420T Top Load Stacked Washer /...
Kenmore 45081 Front Load Washer / Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
