Question about Philips GOGEAR SA6045 MP3 Player
Turning on my mp3
I can not turn my mp3 player on even when i try the power bottom and my mp3 player is a philips nike
  • 47 Answers
Has your MP3 player smashed on something or banged on anywhere?... Coze it may be damaged.
If that's not the case you should check it with new batteries coz old batteries mite be empty
Lastly if none of the others are in place you may have a real problem with your MP3 player and you should go to some technical repair shop to fix.
Posted on Nov 28, 2008
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
I have a Philips/Nike ACT210/17 MP3 Player and when i connect it to my computer to add Music, It says to put it in recvery Mode. How do I do this. I have no Manual
You will need to go to www.usasupport.philips.com to get the manual and software that you need. Be forewarned - this player is completely obsolete - the music service tied to it was discontinued in Oct. 2007 - if you have plugged it into a computer that is running Windows Vista or has Windows Media Player 11 installed, it is already ruined.
Mar 16, 2009 | Philips Nike ACT210 128 MB MP3 Player
Software for mp3 player philips nike psa 220
the disk ???? then tell me wat comes up wen u turn it on like mpman for example
Jul 08, 2008 | Philips Nike PSA220 MP3 Player
Go tothe Philips website and there you can download the software and the drivers for your Player
Dec 07, 2007 | Philips Nike ACT210 128 MB MP3 Player
Transfer music to Philips Nike PSA220 MP3
You probably need to update the firmware of the player to version 2.9, which you can get off the philips website. This is the page for the player which has the firmware and updated musicmatch software they want you to use. Not sure if it will work with Yahoo. http://www.usasupport.philips.com/consumer/productDocuments.html?ProductCode=PSA220/17&subCat=NIKE_PHILIPS_AUDIO_PLAYERS_SU_US_CONSUMER
Aug 28, 2007 | Philips Nike PSA220 MP3 Player
Player wont function ... at all
i have the same problem all the time if you kinda jump start it by holding the power button(play) as you plug it in you can sometime get it to work
Jan 16, 2007 | Philips Nike PSA220 MP3 Player
Problem accessing songs on Philips HDD065/05 Jukebox
What you have to do is this: 1) The HDD Detection tool Connect the device to the PC, load up Musicmatch. On the left click "Portable Device" tab, wait for the PC to show your device. The device should show as "Philips GoGear" if it's showing as "Philips Nike" go to "Tools" on the right, click "Settings" click drop-down menu & choose GoGear. You need to do this everytime you transfer files. If that doesn't work, you need to do this: 2) Manual Re-Install You can re-install the player manually by doing this : - connect the player to your pc by USB cable - uninstall all Installed software for the player - remove device from Windows Device Manager : - Desktop - right click on "My Computer" - select Properties from the menu a new windows appears: System Properties - click on the tab "Hardware" - click on "Device Manager" a new window appears" The Device Manager navigate to the player (should be shown as Philips Nike) at the USB Devices - right click on the player - select "un-install" from the menu - Windows will unsinstall the device - If the player is not listed, the device has been deleted Now to edit the Windows Registry: (Note: Mistakes cannot be un-done so be VERY careful) 1. Disconnect all usb devices. 2. Go to the registry (Start -> Run -> type "regedit") 3. Make a backup of the registry -click "file" -click "export" -Search/Create a logical location ("C:\REGBACKUP" for example) -choose a filename ("registry backup Date.reg" for example) -Please pay attention if Export range is set to "All" -click on save 4. Click on the + infront of HKEY_LOCAL_MACHINE -Click the + of SYSTEM -Click the + of CurrentControlSet -Click the + of Enum -Click the + of USB Here you can remove all VID``s -Before you remove the VID you have to set the right permissions, this can be done as follows: Right click on the folder USB and click on "Permissions", select in the window that pops-up Everyone and and select "Full control" at the permissions. 5. Reboot PC without ANY USB devices connected - install the software and plugins - connect the device to your pc by usb Check if device works and if still showing as "Philips Nike" try the first step again. Hope this helps, Weedy
Dec 20, 2006 | Philips HDD065 MP3 Player
Formatting Problem
That means that the storage on the MP3 Player is corrupt. Replace your MP3 Player.
Jun 30, 2006 | Philips Nike ACT210 128 MB MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
47 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
