Question about HP Compaq Business Notebook NX9010
On/Off power switch will not turn on. Compaq laptop which usually has this problem but seems to always succeed in shifting from off to on if I give the power button a little bit of pressing to the left when pushing down to turn it on. But now it doesn't even do that. I don't know what to do. Any help would be much appreciated. Thank you kindly. TJ San Francisco, CA
  • 93 Answers
Components level Tech like me can re-solder the PIN for you if you can find one near you.
Posted on Dec 01, 2008
  • 748 Answers
I've seen several of these. All have been the connector. On the bottom of you on/off switch is what Compaq calls a button board. This board if OK but it plus into a connector on the mother board. If you look at this connector closely with a magnifying glass as you attempt to remove the button board you'll notice that the connector is coming off the mother board. The pins for this connector are almost as thin as a human hair. I don't know of any way to repair this. HP is only illing to sell a new mother brd. Good luck.
Posted on Nov 30, 2008
Compaq presario b1900 fails to give output to monitor. If output comes out it gives blue screen and shuts down. If you switch on again the fan and disk do run but no output to screen. An external monitor...
That blue screen and shut down, means a problem on both OS and Hardisk.
If you got any hardisk for that laptop. try it and am sure it will work.
The faint beep means a good memory card.
Hope that helps!
Dec 02, 2011 | Compaq Computers & Internet
My Compaq 6735s laptopwill not cut on
Well lets look at the likely options and then discuss.
1. Power button
2. DC power jack
3. Bad motherboard
1. Power buttons seldom go bad and when they do it is usually related to a spill that usually takes out the system board. In my experiance bad power buttons usually dont click or dont click properly.
2. The power jacks often can cause a no power no boot condition but usually you have a clue because it starts acting up after being dropped or wriggling it will cause the power to come on and go off. Not always of course but usually.
3. If the laptop goes off and stays off while playing a game or working with the laptop on your bed or other soft surface. then you can usually suspect the video card went out or some other key system board chip has burned out due to heat or poor workmanship. Dropping the laptop can also cause this problem as can spills.
Solutions.
1. Get a new switch board off of ebay. Usually the power switch is on a little sub-board that is not that hard to replace. Ebay is a good source for laptop parts.
2. These dc jacks can often be resoldered or have wires bypass the weak areas. Sometimes they will break off enough system board to require replacing the board but usually if you have some soldering skills and basic electronic knowledge you can fix it yourself.
3. System board. Again Ebay is the most likely place to find something at a reasonable cost. unless you are mechanically inclined with some geekiness you may not want to try this replacement. There are lots of screws and small components and if you dont do it right you can seriously messup other components or your new systemboard.
Apr 07, 2010 | HP Compaq 6735s Notebook
What does the " Power " light on the dash indicate when it is lit on my Forester 2.0 Turbo S auto ? The manual doesn`t mention it !
Do you have a switch (usually a push button) on or near your shifter labeled "Power" or "Performance"? Some cars have a button that can turn on a different shift program for the transmission, usually holding gears longer and firming up shifts. Once you locate this button press it again and the light should turn off.
Oct 25, 2009 | 1999 Subaru Forester
Hello, sir LT is Compaq prasario V6307 TU,have sound & WiFi prob.
Hi! For Wi-Fi you have to check weather the Wi-Fi switch is off or not ,there is small switch at side off laptop.
For sound you have to check the drivers
Mar 21, 2009 | HP Compaq Presario V6000T Notebook
Cooling fans compaq nx9010
well usually colling fans in laptops are always on. but i have encountered models that seem to temperature controlled, like the one my brother is using. as for the clearance if you can feel the heat of the laptop coming out from the keyboard, you'll need to atleast put some clearance underneath to properly disperse the heat.
Jan 19, 2009 | HP Compaq Business Notebook NX9010
Laptop's primaryhard drive and multibay always on aftr switchoff
control panel
display
screen saver
then power
then advanced in there you can make sure your options are correct
you can check your settings in there for turning off your system
ei/ when you press power button you want it to shut off
Dec 14, 2008 | HP Compaq nc6000 Notebook
Compaq nx9010
Hi - What you see is the fan that cools the main processor:
It will spin to cool the processor when it gets hot so depending on the surrounding air temperature it may not spin. Usually you can feel it spin up briefly when the machine turns on, try placing your hand over the vent when you switch on. If the laptop seems to be running hot & the fan does not spin then you need to get it looked at as overheating will cause a failure in time.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 06, 2008 | HP Compaq Business Notebook NX9010
Latitude C640 is dead!!
The only solution that I can think of would be a power jack problem. I would not advise replacing the power jack yourself since you have to take out the laptop mother board, de-solder the power jack then solder the new one on and put it back together. My advice would be to take it to a professional computer repair shop and have them take a look at it and replace the power jack. It is worth getting repaired since power jacks usually range $40-$70.
Feb 20, 2008 | Compaq Presario 1200XL104 Notebook
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
HP Compaq Business Notebook NX9010 Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
