Question about Pioneer Elite DV-59AVi DVD Player
DVD is stuck inside the player, displays the message SDSP RWER.
After inserting a DVD, the player displays the message SDSP RWER. The player won't play the DVD neither does it eject the DVD. I have tried switching off the power but the same message displays after switching on the power back again. I have tried to check the Troubleshooting section of the manual but there is no mention of the message being displayed in the DVD display.
  • jason May 11, 2010
    this is a service message , you may be able to take it apart and get the player to work again , can you take it apart , or will you need some other info on what you can do?
  • 59 Answers
SOURCE: DVD stuck in DVD player will not eject
I just fixed one of this exact model SD-V392SU with same problem. This takes a bit of manual dexterity, but it can be done with some care and patience.
THE PROBLEM:
There is a small plastic nylon gear on the shaft of a miniature motor in the DVD mechanism. This gear is likely floating loose in the machine. It is what connects the motor's shaft to the rest of the mechanism to operate all it's functions which include opening and closing the tray and raising and lowering the laser and spindle motor that spins the disks. Be careful not to lose it once the lid is removed from the unit. It is quite small.
Unplug the unit and use a well lit area to work in such as the kitchen table covered with a large towel to protect the unit and the table.
There are 5 Philips head screws holding the lid on. One each side and 3 in the back. Remove those paying attention to where they come from. There is a subtle difference in the lengths of the screws. I use empty prescription bottles to keep things sorted when I work.
The lid can be removed by sliding it slightly backwards and tilting the rear of the cover upwards and back. Once the lid is off the unit, you must locate the small white nylon gear that has come off the shaft of the miniature motor that drives the mechanism. A good tip is to lay out a dark colored large towel to shake and dump the loose gear out and onto so you can more easily see it's white color.
REMOVING THE DVD MECHANISM:
There are 2 flat ribbon connectors and one 3pin mini molex connector connecting the DVD mechanism to the main board of the unit. Grasp the cables as close to the connector as you can get.and gently disconnect these by carefully pulling them out. All three are different, so you can't mix them up to put them back.
There are four screws holding the black plastic mechanism in the unit. One long shoulder style screw at the rear center of the mechanism, and three short screws with captive washers. Two of the three short ones are located one on each side of the mechanism towards the front face of the unit and one near the right hand side about three quarters of the way to the rear of the mechanism. A magnetized Number 2 Philips is the best tool for removing and replacing these screws as the two short front screws must be removed from rather tight quarters in the recesses of the unit. The magnet holds the screws on the tip so you can raise and lower them into position while removing and replacing them.
Once the three connectors and four screws are removed, you can lift the rear of the mechanism slightly and tilt the mechanism out of the unit. Once again, keep a sharp eye out for the loose little white gear.
Now that you have the mechanism out of the unit, you can manually eject the captive DVD.
First a little about how this mechanism works.
Look at the front face of the mechanism. You will see a white actuator bar that slides left and right. This is what raises and lowers the laser/spindle assembly. When the mechanism motor spins, connecting gears move this bar raising the laser/spindle motor assembly up. This causes the disk to be clamped against the top of the drive in play mode so the spindle motor can rotate the disk for the laser to read, The disk tray is basically locked when in this position and it can not slide out to give you the disk.
With the gear missing from the mechanism's motor, it will be possible to move that white actuator bar that raises and lowers the laser/spindle motor assembly. Note that there is a switch with three wires on it located on about front face center that is operated by that white bar. This switch tells the mechanism motor when it is loaded and unloaded so the motor knows when to stop spinning as it loads and unloads. Once the bar lowers the laser/spindle, the tray should be able to be coaxed out. Looking at the bottom of the mechanism, you may be able to spot the gear so you can assist the mechanism's white actuator bar, but with the motor's gear missing, the other gears can spin freely.
Once you have your disk out and you have found that little white gear, you can begin the actual repair of the mechanism.
Looking at the bottom of the mechanism, you can see the bottom of the motor the little white gear came off of. This is NOT the spindle motor that spins your DVD's Once you know where that motor is, you can imagine where the shaft of it will appear on the top. Viewing the top of the mechanism, there is a combination of gears that that little gear drives and you should be able to find the motors bare shaft pointing up. This, of course, is where that little white gear belongs.
Now there is two ways to put the gear back on the shaft. I removed the two other gears this one meshes with so I had a little more wiggle room. The other way, of course is to leave the other gears in the way. This makes replacing the small gear more difficult as there is less room for error in placing the gear.
The gear closest to the front of the mechanism has a plastic hook that can be very slightly moved aside to allow that gear to come off it's shaft. Note the difference between the top and bottom of these gears so you know which way they go back on. Once the one with the hook holding it on is off, the other one can just slide off it's axle as it is held in place by the first gear you took off.
I used some Q-tips and alcohol to clean the shaft of the motor and the inside center of the little gear. Then I used a poor man's bearing mount (clear nail polish) and a plastic tooth flossing tool to apply a very thin coating to the inside of the gear and a Q-tip for coating the outside of the shaft to help keep the gear from coming off again. This must be very carefully applied as you don't want any excess nail polish running down the shaft of the motor and getting in the bearings of the motor. There is a special fluid called bearing mount for fixing pulleys and gears on shafts, but I didn't have any of it or the commercially available thread lock. Bearing mount is basically just very thin, watery thread lock like fluid.
I used the small pick end of the tooth flossing tool to position the gear over the motor's shaft and then pressed it back on using a small screwdriver. The gear is very light, so the tackiness of the nail polish was enough to hold it to the tooth pick's curved pick end. Give the nail polish at least an hour to dry before attempting to move the mechanism. Now that the gear is in place, things can't free wheel any more and you don't want to stress the gear before the polish has had a chance to dry.
Once the gear is pressed back on the shaft of the motor, you put the other two gears back where they came from and it's ready to go back in the unit.
Tilt the front of the mechanism down slightly as you slip it back into position. Note that the back end of the mechanism has a small recess where the rear supporting post fits into. All the holes for the screws should be lined up before you start putting them back in. A good tip is that I always turn the screw counterclockwise or reverse after placing it in the hole and wait for it to thump or click down again before turning it clockwise in. That way I know the screw is seating properly and won't cross thread. It turns back in very easily or I reverse again.
Hold the ribbon cables as close to the end as you can as you put them back in their sockets. There is a small amount of reinforcement near the ends of the ribbons to assist in plugging them back in. Otherwise, it's like shooting pool with a rope. :o)
Replace the lid with the rear of it tilted up and slide the front under the face of the front bezel. Everything should fit nicely and the screw holes should all line up. If it doesn't, you've got it wrong, try again.
That's about it. I hope this helps.
Posted on Feb 22, 2009
PERS_Malta
  • 45 Answers
SOURCE: product appears to have frozen and will not eject media DVD
You might have a loosen cable of front panel or dry joints underneath the front panel connector on main board. Patrick
Posted on Jul 25, 2007
SOURCE: dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Posted on Jan 27, 2010
taran_2005
  • 10515 Answers
SOURCE: Pioneer DVL-V888 combo Laser Disc/DVD/CD+G/CD
Unfortunately it seems that the Flash ROM memory that contains the player's firmware is going bad (has a bad integrated circuit chip). The firmware contents most often have a calculated checksum stored with the code/data in ROM. The player at startup compares the read checksum with what it calculates from reading all the ROM contents. When the read versus calculated sums do not match, then it knows, and is alerting you, that some ROM location is going bad and not to trust the player to operate right.
The only thing to do is to have Pioneer fix the player. Sorry!
You could try to disconnect the power supply for few minutes, say 30 minutes and see,if that rests the problem unless repair is the only option.The repair cost i guess, would be anywhere between $100 - $150 plus shipping charges.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 09, 2010
SOURCE: Trying to update firmware on
I had the same problem and immediately suspected that, as I had downloaded and expanded the .zip file on a Mac, I was suffering from the industry's usual bovine shortsightedness and that I needed to do it on a PC. I did and it worked. So I think the important part is to un-archive the .zip file on a PC, and find the file inside the resulting folder called
BDP12X_149.MVP
Make sure you have just that file on your USB stick, and no folders, and then the player should recognise it. You'll note that Pioneer's instructions don't mention this file name at all. Useless. Wish I'd bought another brand.
Posted on Dec 29, 2010
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
After inserting a DVD to play a bought film or recorded disc a message comes up in the display saying No Disc
It may be dust built up and you have to get a DVD insert that's made especially for cleaning the inside of the player
Feb 09, 2012 | Sony Televison & Video
I have a Pioneer DVR 531H and I get the HDD error message What's the solution Barry
I have a Pioneer DVR 530H and I get the HDD error message and freezes
What's the solution
Aug 20, 2010 | Pioneer DVR-530H-S DVD Player/HDD Recorder
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
ERROR MESSAGE.....
had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Jun 24, 2008 | Panasonic DMRES15 DVD Recorder
Disk stuck inside player, LOCK shows on display
Try pushing and holding the power button until lock is cleared. I have a different model daewoo dvrs04 but that's how it works for my dvd. Hope it helps
Mar 16, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Pioneer Elite DV-59AVi DVD Player Logo
801 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
