Question about Jazz DV-179 Digital Camera
The webcam function won't work on my computer
The new hardware screen pops up and i have the disk on it but my computer can't find it? what am i doing wrong?
  • 62 Answers
Your comp asking driver??
if not test the connection of your USB..
Frank
Posted on Dec 08, 2008
My webcam will not work
When you go to Control Panel > Hardware and Sound > Devices and Printers, do you see an webcam icon? It probably won't say HP Webcam but more likely "USB Composite Device". If it isn't there, you'll need to install driver software for the webcam to function. If it is there then right click the icon, click on Properties and look at the General and Hardware tabs to make sure you see HP Webcam in there. You may also want to check to see if it states that the "device is working properly".
Sep 02, 2011 | HP Touchsmart IQ524 PC Desktop
I have a webcam installed inside my computer and it works, but it won't use on yahoo
1st You download Webcam Driver.
webcam installed
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jul 17, 2011 | A4tech PK5
I tryed to reinstall my Ezonics ez-622s120 web cam and it will not work
I dont know what version of windows you are using but here is the link to download the drivers you need to make the webcam work. Either click on the link or copy the link in to your web browser.
http://xpdrivers.com/camera/ezonics/_3_2944.cfm
Now I will tell you a very easy way to install this driver. First unplug your webcam. Then go to the link and down load the correct drivers that work with the version of Microsoft Windows you have on your computer. Once the download completes, double click on the file you downloaded to install the driver.The software may prompt you at some point to plug in the web cam if it doesnt once the download is installed then plug in the web cam. Another window will pop up saying a device or drivers are being installed on your computer. It may prompt you some more it might not. Once the pop window goes away if it doesnt prompt you to do anything then I would reboot (restart) your computer and your web cam should be fully functional then.
I hope this helps you out if it does give me a yes that it was helpful to you. Thanks!
Apr 05, 2011 | Ezonics EZCam Webcam
Laptop integrated webcam is not working can show me a solution ?
Test your webcam here by hitting "allow" in top window and seeing if webcam displays in left panel
http://www.testmycam.com/
1) Working OK = Webcam hardware (cam and connections) are functional and installed software is problem
2) Not working = Fault with hardware - Take laptop to techshop or disable software and install plug-in webcam
Software problem ( as in 1 above )
solution
1) Expand 'imaging' file in Device Manager and right click on text for webcam - 'Update driver' using internet option.
2) Uninstall webcam software, restart computer and re-install using CD ) 3)Uninstall webcam software, restart computer and re-install using webcam manufacture's download from support website
4) Uninstall software and if computer has 'New Hardware Detection' facility reboot allowing the software to install automatically.
Aug 31, 2009 | Computers & Internet
Sorry,you have no video capture hardware video capture will not function properly.
This is indicitive of a driver failure or problem with either the hardware itself or a device conflict with another piece of hardware.
a quick check can be done by going to control panel, system, hardware, device manager.
If you see anything with exclamation marks start there if not then check that your hardware exists in the list
If its not in the list you will need to re-install the drivers / applications software for it.
Remember also that some usb hardware does not like switching to different usb ports which also requires re-install.
If you have it on a usb hub the ensure that the hub has its own power supply and is USB 2.0 not 1.0
Aug 10, 2009 | Trust WB-1400T Webcam
When i insert my usb for my web cam a message pops up saying if your hardware came with an installation cd or floppy disk insert it now but i don't have that disk what should i do
sir try this one and download the driver. after downloading install it on your computer so that the webcam will be recognizable on your computer. you can use it after the installation.
http://www.dirfile.com/philips_webcam_pcvc665.htm
thank you for using fixya
CHARCOIS
Nov 28, 2008 | Philips J44414
Webcam help
Check that your usb ports are functional by plugging in another known good working device, mouse, etc. Most devices want you to install the CD before you connect the hardware. When it's asking you for the drivers, be sure you point it manually to the folder on the disk with the .INF files. The INF file tells the computer what DLL and System files to load to use your device. Check under the Device manager to see that the device is installed all the way or if it has a question mark on it saying something is wrong.
Jan 04, 2008 | Computers & Internet
Acer Crystal Eye Web Cam
APPCRASH
if you saw something like this on your vista. try to remove all subfolders from folder my pictures. on mine it works
(see screenshotfa5d811.jpg)
Nov 07, 2007 | Acer Aspire 5610-4648 Notebook
Jazz DV-179 Digital Camera Logo
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
